15ExpLimited
- February 16, 2025
- Camden, NJ
- 2015 Limited N/A 4WD
Hi all, I have a 2015 Explorer Limited 3.5 N/A without a drain plug on the PTU, and I regularly take the car off-road, climbing muddy steep hills and moguls and getting 1-2 wheels off the ground, I know the PTU's are a weak spot on these explorers; and Ive already changed the fluid once and added the tow package underbody air duct as this is a factory non tow package vehicle (also tried doing the vent extension mod and then dismally found out TT ecoboosts have a vent and N/A's use a one way valve pressed directly into the case of the PTU), but im still paranoid about the PTU, does anyone know the thread pitch of the PTU's fill port? would it be possible to thread an aftermarket temp sensor in place of the old fill port and maybe wire up a tiny gauge on the interior?
