  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
2015 Explorer Shudders when in park , running and a door closes
Scottysgirl
Burney, California
2015 Ford Exp Limited
I have searched the form and see things for shuddering while driving (not the issue I am having) So if I am placing in the wrong place I am very sorry! I have a 2015 Ford Explorer Limited. While the car is running and placed in park, if someone gets out and closes the door the whole car shudders. It will also do this when I place the car in park and shut it off...it shudders the whole car as well (that's a new one). It will also shudder while in drive but my foot is on the break and someone closes a door. Sometimes it just does it while idling. Most of the shuddering seems to center around the park position, foot on brake and closing of doors while in the park position and running. Just wondering if anyone has experienced the same problem and might have a solution or recommendation for me. Please help if you can.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
I'm guessing you are talking about engine shutter and not the actual body. Is that right? I don't recall anyone else posting a similar issue. No issues when driving or going over bumps etc?
03WIExplorerLtd
2011 Explorer FWD base
Motor mounts, trans mounts. There are three total.
Might be worth have checked out.
Scottysgirl
Burney, California
No, it's the actual car. The whole body and wheel.None when driving. Sometime when I first drive it in the morning it feels kinda shaky but it's in the exact spot every morning and doesnt do it again until the next morning. I'm assuming that's the road.
Scottysgirl
Burney, California
Unless the engine is shaking the entire car?
03WIExplorerLtd
New tires can have flat spots that vibrate moderately when first driven.... for couple miles
Could be suspension issues, misfiring, etc. I am just guessing, sorry. Trying to help......
Have a dealer or independent shop check it out, my recommendation.
peterk9
Staff member
Moderator
Callsign
VE3
tsawyer
Westchester, NY
2014 Explorer Sport
I have this exact same issue. Did you ever get to a root cause? It was happening primarily with the passenger front door, but now I can replicate it with the driver side front as well. I can't get it to happen 100% of the time, but I am hoping to reproduce it for a service tech sometime soon.
peterk9
Staff member
Moderator
Callsign
VE3
Hopefully the member is still following the thread. Last activity was Aug. 1, 2019.
3 2015 Explorer Sport - Shudders when coming to a stop. Stock 2011 - 2019 Ford Explorer Discussion 11
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
D 2015 Explorer Brake Issue?? Stock 2011 - 2019 Ford Explorer Discussion 14
G 2015 Explorer Rear Suspension Questions Stock 2011 - 2019 Ford Explorer Discussion 2
S 2015 explorer won't start Stock 2011 - 2019 Ford Explorer Discussion 1
F 2015 Explorer Limited Air Bag Light Stock 2011 - 2019 Ford Explorer Discussion 0
M 2015 Explorer missing dash climate control Stock 2011 - 2019 Ford Explorer Discussion 2
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
B 2015 Explorer XLT LH Headlight Bulb Replace Stock 2011 - 2019 Ford Explorer Discussion 5
C 2015 Ford Explorer Keeps blowing interior light #12 fuse. Stock 2011 - 2019 Ford Explorer Discussion 2
W 2015 Explorer XLT, No low speed fan with AC on Stock 2011 - 2019 Ford Explorer Discussion 13
B 2015 Explorer sport water pump replacement Stock 2011 - 2019 Ford Explorer Discussion 12
H 2015 explorer four cylinder eco boost ticking noise Stock 2011 - 2019 Ford Explorer Discussion 3
P 2015 Ford Explorer Limited stalling at intersections/idle Stock 2011 - 2019 Ford Explorer Discussion 4
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
J Aftermarket Radio Upgrade 2015 Explorer Stock 2011 - 2019 Ford Explorer Discussion 3
H 2013-2015 Explorer Sport Questions ( new to the vehicle ) Stock 2011 - 2019 Ford Explorer Discussion 3
J 2015 Ford Explorer Sport BCM Issue Stock 2011 - 2019 Ford Explorer Discussion 12
B 2015 Explorer Sport HVAC Issue Stock 2011 - 2019 Ford Explorer Discussion 11
T 2015 Explorer Air, ambient lighting, outside temp gauge stopped working Stock 2011 - 2019 Ford Explorer Discussion 4
M 2015 Explorer Sport Side Mirror Turn Signal Stock 2011 - 2019 Ford Explorer Discussion 2
1 2015 Explorer vibration Stock 2011 - 2019 Ford Explorer Discussion 3
E fan speed fluctuates on 2015 ford explorer air conditioning Stock 2011 - 2019 Ford Explorer Discussion 6
C 2015 Explorer Limited towing 27', 4700lb TT Stock 2011 - 2019 Ford Explorer Discussion 0
S 2015 Explorer Sport [VIDEO] Help identify this fan or belt noise seconds after engine turns off Stock 2011 - 2019 Ford Explorer Discussion 8
G Can bus pin configuration Ford Explorer 2015 Stock 2011 - 2019 Ford Explorer Discussion 7
Partsman109 2011-2015 Explorer front turn/parking lamp...is there a cool way to minimize the amber? Stock 2011 - 2019 Ford Explorer Discussion 6
A 2015 Ford Explorer Cold Start Rattle Stock 2011 - 2019 Ford Explorer Discussion 1
A Random starting issues 2015 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
A 2015 Explorer Sport Power Transfer Unit (PTU) Stock 2011 - 2019 Ford Explorer Discussion 9
B 2015 Explorer XLT Door Chimes with key not in the ignition Stock 2011 - 2019 Ford Explorer Discussion 6
B 2015 Explorer Sport center console lighting issue Stock 2011 - 2019 Ford Explorer Discussion 1
D 2015 Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 2
U 2015 Explorer PIU Suspension Noise Stock 2011 - 2019 Ford Explorer Discussion 9
G 2015 Explorer Cross Bars Stock 2011 - 2019 Ford Explorer Discussion 2
R Re-use a 2015 Mustang key fob for 2017 Explorer Stock 2011 - 2019 Ford Explorer Discussion 25
K 2015 explorer sport bouncing Stock 2011 - 2019 Ford Explorer Discussion 9
C 2015 Explorer headlights Stock 2011 - 2019 Ford Explorer Discussion 5
H 2015 Ford Explorer need help Stock 2011 - 2019 Ford Explorer Discussion 4
A 2015 Explorer Sport - Check Charging System Stock 2011 - 2019 Ford Explorer Discussion 7
U 2015 Explorer Issues Stock 2011 - 2019 Ford Explorer Discussion 9
G 2015 Explorer Battery Goes Dead - Intermittently Stock 2011 - 2019 Ford Explorer Discussion 0
J 2015 explorer XLT FWD rear suspension issue Stock 2011 - 2019 Ford Explorer Discussion 1
P Overheat light on 2015 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 6
M In search of 2015 explorer xlt black glove box Stock 2011 - 2019 Ford Explorer Discussion 5
Z Can I Swap 2016 Explorer Seats into my 2015 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 0
F 2015 Ford Explorer AC fan speed changes randomly without adjusting the knob Stock 2011 - 2019 Ford Explorer Discussion 7
T Buying used 2015 Explorer, question. Stock 2011 - 2019 Ford Explorer Discussion 9
J Max. cargo area length 2015 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 9
I 2015 Explorer XLT, front tie-downs? Stock 2011 - 2019 Ford Explorer Discussion 1
Similar threads
