2016 2.3L oil change too much oil?
onedownfiveup
Kansas City
2016 Ford Explorer XLT
Ive worked on cars and motorcycles for over 2 decades. I saw 5.7 qts of oil for this engine. I drained it until it was barely dripping and replaced the oil filter. I filled up the oil filter with oil and put 5 qts in. Started it up and let it rest. Pulled he dipstick and it appears as though I have way too much oil in this thing. It has maybe 5.2 qts now and it seems as though it’s over filled. I flip the dipstick over to the opposite side and it looks like I get a better reading. Is this normal?
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
I changed the oil on mine not long ago, and I noticed dip-stick direction did matter in reading the right level. I lent my car out for a week or I'd run out and check which direction it's in now, but I filled mine up per the manual (which holds 6 quarts although the manual says something else) and thought I had overfilled. So I let some oil out and kept checking. In the end, it turned out I had underfilled and had to add more. It's not easy to read new oil on the stick as it's so light in color, but the direction mattered for me.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I would fill it to what the manual says, and not worry about it. If you put in the recommended amount I’m sure it’s not overfilled. Drive it a week or two and recheck when it’s picked up done color.
onedownfiveup
Kansas City
I think I'm just so used to higher mileage engines. This motor has 17k on it and the Mobil one is just so clear on the dip stick it drove me nuts I couldn't get a good reading on it.
JAPeterson
Gypsum, Co
2016 XLT
One thing that you can do if you are having problems seeing where the oil level is on a oil change is to drill a small hole in the dipstick at the full level, that is if there isn't already a hole there.
I hate it when the manufacture tells you that the oil fill capacity is something like 5.7 quarts. I just put in the full 6 quarts and let it go at that. An extra three tenths of a quart is not going to hurt it.
onedownfiveup
Kansas City
Putting too much oil in isn't good for it.
JAPeterson
Gypsum, Co
2016 XLT
Three tenths isn't that much oil. A quart yes.
Take a look at your oil bottle and measure the tenths on it and then see just how much we are talking about.
KayGee
Farmington, MI
'16 & '17 PIU
Possibly silly questions, but here goes anyway...
What was the oil level reading before you changed the oil?
Did you capture the drained oil in a clean/empty receptacle and measure it to confirm what came out?
Did you change the filter?
Is the vehicle on level ground when checking oil level?
onedownfiveup
Kansas City
All good questions.
I didn't check it before I changed it.
Yes, it filled up a 7qt drain pan so probably close to 6 quarts.
Changed the filter with the same filter that was on it.
Vehicle was on level ground.
KayGee
Farmington, MI
'16 & '17 PIU
Is this a new vehicle for you? First time changing the oil? Have you checked oil level before and has the dipstick read correctly?
Taking out 6 qts, putting in 5.2 qts, and seeing an overfill reading on the dipstick seems odd for a vehicle with a 5.7 qt capacity.
Maybe you have a defective/wrong dipstick?
shucker1
Metairie, Louisiana
98 XLT 5.0
Perhaps the manual references 5.7 Quarts with an empty external cooler if you have one?
If you over fill by several quarts then you run the risk of having the crankshaft counter weights splashing the oil around and causing foaming problems as well a vibration issues.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Just checked mine. Explorer had an oil change done by the dealer on April 6th. Fluid level was just above the 2nd hole on the dip stick so about 1/4" above the full line. It also made no difference in the way to dip stick was inserted. Same reading all the time. Mine calls for 5.7L (6 qt) so I'm guessing they just put in the full 6L.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Spec is 5.7 qts and 5w30 syn blend. This includes the filter.
peterk9
Staff member
Moderator
Callsign
VE3
That is for the U.S. Explorers. The ones for the Canadian market come with regular Premium oil with synthetic blend or full synthetic as an option.
onedownfiveup
Kansas City
The crank already splashes through the oil.
onedownfiveup
Kansas City
Anyways, my wife drove it to work and back yesterday and I checked it last night. Oil is at the full level with 5.7 qts in. It just took it some time to make it a little dirty to read.
shucker1
Metairie, Louisiana
98 XLT 5.0
whimsey
sparta, nj
2017 XLT
I have a 2017 Explorer with the 2.3 EB. I put in exactly 5.7 quarts. AFTER it sits for 20+ minutes it will read full on the dipstick. It takes 20 minutes to drain into the oil pan.
Whimsey
shucker1
Metairie, Louisiana
98 XLT 5.0
Should take about that long for all of the oil in the top of the engine to drain back down.
L How to: PTU Oil Change (Tons of Pics) 2016 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 204
H 2016 sport first oil change .... Stock 2011 - 2019 Ford Explorer Discussion 12
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
G 2016 Explorer Sport Jerking/Stall Cabin oil smell Stock 2011 - 2019 Ford Explorer Discussion 2
J 2016 oil drain location Stock 2011 - 2019 Ford Explorer Discussion 17
M 17s with bigger tires on 2016 Sport?? Stock 2011 - 2019 Ford Explorer Discussion 2
H 2016 XLT Stalled and Wont Start Stock 2011 - 2019 Ford Explorer Discussion 1
H 2016 XLT Driver Side Grounding Strap Stock 2011 - 2019 Ford Explorer Discussion 2
T Has anyone modified their 2016+ so they can turn off their headlights? Stock 2011 - 2019 Ford Explorer Discussion 9
T Options for replacing LED low beams 2016+ Stock 2011 - 2019 Ford Explorer Discussion 4
H 2016 Explorer XLT Cooling and AC issues Stock 2011 - 2019 Ford Explorer Discussion 5
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Sport drops power or boost under load Stock 2011 - 2019 Ford Explorer Discussion 2
P 2016 Explorer Liftgate Panel Removal Stock 2011 - 2019 Ford Explorer Discussion 2
D 2016 Ford Explorer trans slips colder temps Stock 2011 - 2019 Ford Explorer Discussion 6
N Ambient Air Temp Sensor Replacement 2016+ Stock 2011 - 2019 Ford Explorer Discussion 1
J 2016 Limited Rear Brake Pads Stock 2011 - 2019 Ford Explorer Discussion 7
M 2016 Explorer LED signature light - only one on with ignition on Stock 2011 - 2019 Ford Explorer Discussion 8
S 2016 2nd Power Point Stock 2011 - 2019 Ford Explorer Discussion 1
M REAR BACK UP SENSOR 2016 XLT Stock 2011 - 2019 Ford Explorer Discussion 1
J 2016 Explorer transmission ratting noise Stock 2011 - 2019 Ford Explorer Discussion 2
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
D 2016 Explorer Wiring Diagram Stock 2011 - 2019 Ford Explorer Discussion 6
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
J 2016 Sport Wiring Issue? Stock 2011 - 2019 Ford Explorer Discussion 2
R Just got 2016 explorer xlt with 20s, I have a question. Stock 2011 - 2019 Ford Explorer Discussion 11
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
J 2016 keypad entry Stock 2011 - 2019 Ford Explorer Discussion 0
T 2016 Explorer Postive battery cable replacement Stock 2011 - 2019 Ford Explorer Discussion 1
W 2016 2.3 fwd rpm hunting Stock 2011 - 2019 Ford Explorer Discussion 3
T 2016 vs 2018 Explorer purchase Stock 2011 - 2019 Ford Explorer Discussion 11
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
C Door handle 2016 Stock 2011 - 2019 Ford Explorer Discussion 1
S 2016 blowing AC clutch relay fuse #16 Stock 2011 - 2019 Ford Explorer Discussion 2
D 2016-Need to calibrate blend door actuator after replacement Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 XLT ecoboost (non sport) Shuts off while driving Stock 2011 - 2019 Ford Explorer Discussion 4
S 2016 Ex Passenger Door Unlocking and Alarming with No Keyfob Stock 2011 - 2019 Ford Explorer Discussion 0
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 sport throwing p0327 code Stock 2011 - 2019 Ford Explorer Discussion 1
S Slow Start Long Crank 2016 XLT Stock 2011 - 2019 Ford Explorer Discussion 6
Sentry6 Sony control panel, touch panel upgrade to 2016 -19 style Stock 2011 - 2019 Ford Explorer Discussion 1
A 2016 Ford Exploer Sport LED Foglights Stock 2011 - 2019 Ford Explorer Discussion 2
U Contribute your experience: Ford Explorers 2016-2019 Stock 2011 - 2019 Ford Explorer Discussion 11
M 2016 Explorer Sport Lemon Stock 2011 - 2019 Ford Explorer Discussion 4
Similar threads
