2016 Ex Interceptor Police Lighting
PDExplorer
Long Island, NY
16 Xsport, 12 Mustang GT
Any better pics of the rear area, left and right, without the molding and trim? I usually like to cheat when running wires in my car and this is a nice sneak peek behind there lol
1995E
Maryland
95 + 11 Ex both XLT
Its a great idea but when several agencies tested it the GPS probes were not holding on the badguys car. Im not sure if they updated this or not. They need to be non removable so badguy does not pull into an underground lot and throw it away.
Is it magnetic? Wouldn't work on those aluminum body cars.
jade97
S.E. Pennsylvania
2016 Sport & 2018 Edge
This would be great...I'm trying to run a cb coax from above the DS taillamp (Firestik door jamb mount) into the inside of the vehicle to the DS lower dash area. I want to limit drilling into the vehicle and I only have 18 ft of cable, with the ends already mounted.
I cannot run it up by the hinges because that grommet is already filled with the power liftgate harness.
NickyB
Massachusetts
2016 Ford Explorer Sport
Interceptor the Same as a sport as far as set up?
I am an on-call fire fighter and am looking to mount my siren. I know you have a Police Interceptor and mounted your siren using Whelen's SAK44 bracket. Do you know if the civilian trims will also be the same set-up to use this bracket. I looked up "Alarm" like someone stated but am somewhat confused. My car is obvs going to have the factor alarm installed, is that where the OEM alarm speaker would be where the siren speaker would have to go? If that doesn't make sense please let me know and I would be happy to clarify. I also have a second question and that is where is the best spot to get through the fire wall?
Sgt1411
VanBC/GoodyearAZ
2021 Explorer ST
Callsign
PRINCE51
Download the Upfitters Guide at www.fordpoliceinterceptor.com
It speaks to the OEM access through the firewall behind the glovebox.
Might also help you with your speaker mount.
NickyB
Massachusetts
Thanks, I just checked that out, I'm a little nervous about disconnecting an airbag, something I've never done before, but I'll at least check that out. Thanks! Didn't find anything about the mount location of the speaker though.
Nick
asull85
The Storm Chaser
Agawam, MA
2016 Interceptor Utility
Callsign
WX4FUN
Nick
Disconnect the battery before you do.
