2016 Explorer 2.3 Ecoboost Idle Issue
Jeffreylynn
Wilmington, NC
2016 Explorer Limited
I have a 2016 Explorer when in gear foot on brake like at a stop sign idles low 500 rpm or less and acts as if it wants to shut down. Recently had to replace transmission but had the idle issue prior to and after replacement. Have eliminated vacuum, plugs, coils, injection cleaning as potential causes. Also had Ford dealer reflash PCM. Dealer wants to say it is torgue converter drag but transmission shop checked with their scan tools and said torque converter was performing correctly. Also highly unlikely two different converters have the same issue. Computer shows no codes pending or otherwise. At wits end anyone have an idea?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
94Eddie
2010 Mountaineer Premier
I believe your year of Ecoboost engine has a single fuel injector GDI system. These engines often have carbon buildup on the intake valves. The carbon can build up to the point that rough idling/running can occur. It is not easy to remove the carbon but some intake cleaning products can remove enough to solve the problems this can create. Also, it is not uncommon for this condition to throw off no codes or ones that don't tell you where the real problem lies.
I think Ford switched to the dual injector design in 2017 which placed an injector just before each intake valve. This injector sprays occasionally to wash the carbon off the valves which keeps it from building up.
Jeffreylynn
Wilmington, NC
I had a three part fuel induction system service performed with no change to idle issue. Also the car runs great when under way. Problem only when stopped in gear with foot on brake. I ask dealer if not torque converter then what. They basically had no answer except possibly the pcm.
Adrian Gitch
Paris, KY
2015 Explorer Limited
Just throwing a guess out there, maybe throttle body?
Jeffreylynn
Wilmington, NC
Really hoping someone had seen this exact issue before. Trying to avoid just throwing anymore money at it without a good chance of it fixing the problem. At this point considering taking a whupping and trading it as is. Benn one of those never seen it before problems which is hard to believe with the numbers of these vehicles on the road.
94Eddie
The only way to confirm if this is a problem is to look at a few intake valves with a scope. From what I have seen from tests showing the effectiveness of the treatments is they don't work all that well and can take multiple applications to remove enough deposits to see a difference. Some of the intake valves I have seen have a massive amount of carbon built up on them. This isn't only a problem with Ford Ecoboost engines with one injector per cylinder. Many other brands have the same problem. These videos give some good information regarding this problem on the 2.3L Ecoboost engines.
Jeffreylynn
Wilmington, NC
Thanks for the info. Would the the carboned up valves only create an issue at idle. Seems like it would show itself at other conditions while driving. Hesitation, skipping, or fuel mileage.
94Eddie
I can't say if this is causing your issues. It could be either causing your problem or contributing to it. Did you watch the second video? He talks about his experience with symptoms and the results of removing carbon from certain intake valves. Also, listen to his comments on the effects of carbon deposits regarding turbo failure.
2016FordJerry
Miami Lakes, FL
2016 Ford Explorer XLT
I am currently experiencing the same symptoms and going through the same issues. In pursuit of a solution Ford fixed my gas tank (some seal), Transmission mounts (not an expert but never heard of these), Tune up with plug change, another fuel system repair, more I cant remember. I have had my car in about 6 times and tomorrow it goes back for #7. I have noticed slight improvements with each repair but over all the issue remains constant. I do also notice some "sputtering" during driving and acceleration.
Last time it was in they noticed carbon in one cylinder greater than the others and theorized it may be a fuel injector.
I am checking the videos now and hopefully there is enough there to point them in the right direction.
I would ask anyone here, my wife had a 2003 Mazda 6 when Mazda was owned by Ford, and she had similar issues which ended up being one of the coils. This couldn't be similar to that?
Thanks in advance and I hope some info I shared may help others.
peterk9
Staff member
Moderator
Callsign
VE3
^^ Welcome to the Forum. :wave:
Which engine do you have?
