maciek1312
- August 27, 2018
- Denver, CO
- 2016, Explorer XLT
2016 Explorer XLT, 3.5 L (Duratec) AWD
What's the issue?:
After sitting in park, when I shift into D (or after reversing from a parking spot and then shifting into D) and I go to drive away, the first gear shift from 1st to 2nd, I always encounter an audible, but brief grind. I can even feel the shudder in the gas pedal (it vibrates just slightly). For the rest of the duration of my drive, I don't encounter this issue again, even after sitting at a red light or pulling over for a moment. I only hear/feel the grind when the car has been parked. This grind happens every day and every time I pull away from a parked position.
Within months of purchasing back in 2016, I took it in to have this same issue checked out. (I purchased used with 10k). They replaced the PTU and the Tech's notes read:
"Verified CC and ran OASIS no info found noise coming from PTU assembly remove fill plug to inspect fluid. Fluid is contaminated and full of metal AUTH to replace with exchange unit due to lack of repair parts or procedures remove PTU install exchange unit verify proper fluid level fill trans to spec at operating temp and test drove to verify repairs"
I didn't hear the grind again for maybe a couple weeks. Since then, I hate to admit, I just kept driving and dealing with it. However, with warranty drawing to a close, I wanted to get it checked out one more time, SO, I am actually taking it in tomorrow and I hope to: 1) Update with results and 2) see if anyone else had a similar issue.
THANKS!
What's the issue?:
THANKS!
