2016 Explorer LED signature light - only one on with ignition on
mobius00
Poland
2016 Limited
Hi there all,
It is Ford Explorer 2016 limited, with the following settings:
Autolamps ON (rotary switch),
Daytime Lights - ON (check enabled) in the cluster's settings,
All doors closed,
Gearbox in Park,
Ignition ON,
Engine OFF.
Bunch of FORScan settings modified, can't recall anything to do with these LED lights though...
Ends up with only one LED signature light on :eek: .
What is / could be the problem?
Mechanical / Electrical / FORScan settings? :help:
Upon turning on engine AND putting Drive / Reverse - both sides of the signature light are on OR when opening the doors - both sides light up.
Thanks a lot in advance for all the hints!
MM07
MA
2018 Explorer Limited
Did it work before any FORScan changes?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Do both come ON when in 'Park' with the engine running? Have you tried tapping on the light to see if it will come ON when in 'Park' with the engine OFF? It is a strange issue but at least they are both ON when it counts.
mobius00
Poland
2016 Limited
1. No, not in Park, only when I put it to Drive /Reverse.
2. I have not tried tapping, I will, but I don't think it's this, as it works flawlessly in certain conditions.
3. True that, both on when I need them.
mobius00
Poland
2016 Limited
reverting BCM to the original settings in Forscan did not help. Also, I could not find any other Lighting module...
mobius00
Poland
2016 Limited
Unless it's dark, then all 4, i.e. 2x headlights and 2x led signature lights are on (park & engine off or on)
btw. tapping didn't help...
peterk9
Staff member
Moderator
Callsign
VE3
Software issue ❓:dunno:
