  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
2016 Explorer Remote Start Climate Behavior
cwescapexlt4x4
Explorin' the Desert SW
Litchfield Park, AZ area...
2016 Explorer LTD (FWD)
I got to thinking about this change with the 16+ remote start/climate control... and if it is POSSIBLY due to the emissions issues with the rear of the vehicle and preventing the system from drawing CO2 from the rear.... food for thought.
cwescapexlt4x4
So I tried today using the "Last setting" vs. "Automatic" in the left side vehicle controls and the front AND the rear were full blast as I had left them hours earlier. .... so there's hope.
tlynch41
San Juan Capistrano
2016 Explorer Limited
When I use the remote start, it does not activate the A/C until I get in car and press the ignition. Is there a way to tell it to turn on the A/C too?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
What is your setting in the left information display? It should be set to 'Auto'. That is covered in the Owner's Manual.
The heating and cooling work the same way. They come on at a low volume and don't turn on full until you get in and hit the 'Start' button. No way around that using the settings available.
peterk9
Staff member
Moderator
Callsign
VE3
Your thread was merged with this one.
tlynch41
San Juan Capistrano
OK thank you. But what good is remote start if you can't adjust the temp inside the car?
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
^ The other option is that you can set the vehicle to use the last settings that were in place before the car was turned off.
tlynch41
San Juan Capistrano
I tried the "last setting" option, set it to max a/c before I turned off car, and it worked! Sounds like a software bug to me.
peterk9
Staff member
Moderator
Callsign
VE3
Just remember that using "Last Setting" will not however activate the following as indicated on page 136 of your Manual;
• Heated seats.
• Cooled seats.
• Heated steering wheel.
• Heated mirrors.
• Heated rear window.
cwescapexlt4x4
• Heated seats.
• Cooled seats.
• Heated mirrors.
Here in Phoenix, we don't need any help with "heated" anything.... :) LOL but yeah once out of summer i would probably switch back to Auto
I also wait a few minutes after driving to turn on cooled seats.
peterk9
Staff member
Moderator
Callsign
VE3
Diveshard
Location
Gatineau, Quebec
Gatineau, QC, Canada
2016 Explorer XLT V6
I recently purchased a 2016 XLT and love it BUT I am experiencing the same situation and its driving me NUTS. Its getting cold here in Canada. Wether I leave the setting to Auto or to the Last setting when I get in my car that was remote started the vent speed is at its lowest and starts right up when I push the ignition.
Is this a known bug? If I bring it to the dealer can this be fixed?
thanks
peterk9
Staff member
Moderator
Callsign
VE3
thanks
That is normal in the 'Auto' setting,
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
thanks
LMAO, when I first got my EX around winter time and getting used to things, I initially though I was shutting the car off accidentally, as it goes from full blown hurricane speeds to whisper quiet.
DraftEdison
Location
Iowa
16 Explorer XLT 202A AWD
Seriously I NEED HEAT!
Before you think it, I have read the owners manual twice but am still frustrated by the heat controls in my 16 EX. And to complicate matters, how it works with the remote start... I typically use the "auto" settings but have found that the defrost does not work when I need heat! I know Detroit is in a cold climate, why can't I have both operational? We have times when you need the defroster running while also trying to not freeze your you know what off. All I can get to happen is the defog on at the same time as the floor setting. What am I not getting (besides HEAT!)?? Also, when I use the remote start there is air blowing but it rarely actually defrosts the front window and when I get in and actually start it, none of my previous settings are on? wth? I have even changed the settings on the dash to "last setting" but it doesn't do anything different. Also, on a side note, what does "system" mean in the settings for the remote start? Mine is "checked".... Help I am freezing to death!
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
It has always been defrost only or defrost and floor. You have never been able to do defrost and face.
When set to Auto, it does what it needs to do to warm the vehicle up to the desired temp you ha e set.. it doesnt say "ill just defrost the window for a bit and then switch to whatever I want".
If you want it on defrost, put the defrost setting on before you shut the Ex off and when you remote start, it will do the last setting that was chosen.
And yes, when you get in from a remote start and "start" the vehicle essentially disabling/overriding the remote start, the HVAC system reboots itself esentially turning on from a key/fob start. It has been this way since 2011MY and all Ford vehicles with MFT/sync.
jhu8
Maryland
17 Ford Explorer Limited
I agree the system is really not ideal. When you remote start the car and the car realizes its cold, it should put defrost to MAX. Regardless. I believe it does this but even after running for five minutes, when I get in, the fans are running very slowly. What good is that? It's not! So I have to sit there even longer after turning it to full blast to finally defrost the windows.
I think the problem is the car is just trying to warm up to say 74 degrees or so. A middle comfortable temperature. Is there a way to change this set temperature? I always get out with it around 80 or so but its not set to that when I get in after remote starting. I guess I could set it to perform last setting but with if I have it on my face and feet before getting out of the vehicle. Having it on the face and feet when I remote start in the morning is pointless and will not defrost any window.
peterk9
Staff member
Moderator
Callsign
VE3
The defrost and floor setting should provide heat. Don't forget that the fan will only come on full once the coolant/engine has warmed up. My vehicles have always been on defrost and floor and rarely if ever on the vents above the screen. I believe that I've read that if you leave it on 'Last Settings' that you will get the fan to run faster with remote start but then the other features that come on with the 'Auto' setting won't work. Remote start with the 'Auto' setting will engage more features but the fan will only pick up speed once you hit the Start/Stop button in Explorers that have that or turning the ignition ON.
peterk9
Staff member
Moderator
Callsign
VE3
Your thread was moved to this one covering the same issue. See some of the earlier posts on this page. There are other threads about this issue as well that you can try and find with the Forum's 'Search' feature.
S 2016 Explorer Remote Start - HELP Stock 2011 - 2019 Ford Explorer Discussion 6
J How to: 2016 Explorer- Adding Remote Start Facts Stock 2011 - 2019 Ford Explorer Discussion 94
H 2016 Explorer XLT Cooling and AC issues Stock 2011 - 2019 Ford Explorer Discussion 5
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
P 2016 Explorer Liftgate Panel Removal Stock 2011 - 2019 Ford Explorer Discussion 2
D 2016 Ford Explorer trans slips colder temps Stock 2011 - 2019 Ford Explorer Discussion 6
M 2016 Explorer LED signature light - only one on with ignition on Stock 2011 - 2019 Ford Explorer Discussion 8
J 2016 Explorer transmission ratting noise Stock 2011 - 2019 Ford Explorer Discussion 2
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
D 2016 Explorer Wiring Diagram Stock 2011 - 2019 Ford Explorer Discussion 6
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
R Just got 2016 explorer xlt with 20s, I have a question. Stock 2011 - 2019 Ford Explorer Discussion 11
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
T 2016 Explorer Postive battery cable replacement Stock 2011 - 2019 Ford Explorer Discussion 1
T 2016 vs 2018 Explorer purchase Stock 2011 - 2019 Ford Explorer Discussion 11
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 Explorer Sport Lemon Stock 2011 - 2019 Ford Explorer Discussion 4
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
L 3000 RPM noise 2016 explorer 2.3l Limited Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 Explorer power door lock issues Stock 2011 - 2019 Ford Explorer Discussion 7
C 2016 Explorer Limited power gate won't close Stock 2011 - 2019 Ford Explorer Discussion 5
C Best baby seat and base for 2016 Explorer Stock 2011 - 2019 Ford Explorer Discussion 7
T 2016 Explorer 4 Cyl Ecoboost Rough Idling Stock 2011 - 2019 Ford Explorer Discussion 24
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
N Ford Explorer 2016 AC not working grey out Stock 2011 - 2019 Ford Explorer Discussion 10
M 2016 Explorer Sport Tail Light Part? Stock 2011 - 2019 Ford Explorer Discussion 3
B 2016 Explorer seat mysteriously moves all the way forward Stock 2011 - 2019 Ford Explorer Discussion 20
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
P 2016 Ford Explorer Sport brake job Stock 2011 - 2019 Ford Explorer Discussion 0
H 2016 Ford Explorer Limited Speaker and Amp Upgrade - Help Sought Stock 2011 - 2019 Ford Explorer Discussion 1
H Help - 2016 Ford Explorer Limited - Won't Start Stock 2011 - 2019 Ford Explorer Discussion 3
P 2016 Explorer Hands Free Liftgate Not Working After Factory Hitch install Stock 2011 - 2019 Ford Explorer Discussion 7
M 2016 Explorer XLT PTU *PICS* Stock 2011 - 2019 Ford Explorer Discussion 35
E 2016 Explorer Parking Assist ...Ugh!! Stock 2011 - 2019 Ford Explorer Discussion 0
N 2016 Explorer. ECU location Stock 2011 - 2019 Ford Explorer Discussion 0
J Disabling interior lights in 2016 Explorer XLT? Stock 2011 - 2019 Ford Explorer Discussion 7
J 2016 Explorer XLT 4x4 turns off Stock 2011 - 2019 Ford Explorer Discussion 32
M 2016 Explorer Front End Wiring/Plug Help Stock 2011 - 2019 Ford Explorer Discussion 3
0 2016 Explorer stereo wiring diagram Stock 2011 - 2019 Ford Explorer Discussion 3
D HELP Tons of codes and Battery not keeping charge 2016 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 24
L 2016 Ford Explorer PTU Drain Plug Size Stock 2011 - 2019 Ford Explorer Discussion 7
T Brake pads for 2016 explorer - ceramic or semi metallic? Stock 2011 - 2019 Ford Explorer Discussion 35
S 2016 Ford Explorer 2nd Row Bucket Seats Stock 2011 - 2019 Ford Explorer Discussion 8
Similar threads
