2016 Explorer Remote Start Climate Behavior
Mlarv5
Crossville TN
2017 Platinum Ruby Red
Before you can have heat the engine has to be above the temperature you set. Let’s say it is 10 outside and you left the EX out all night. The engine coolant is 10 degs. You start up the engine remote or by key. You set the temp to 75. The engine has to be above 75 to even start to provide heat. You turn on the inside fan to max it cools the coolant temp from 75 down to below that because of the heat exchanger or heater core. When engine gets above 100 it will start heating the cabin. On my 17 I hit auto and let it run for 10 or 15 minutes on remote start before heading out.
Mlarv5
Crossville TN
Your thread was moved to this one covering the same issue. See some of the earlier posts on this page. There are other threads about this issue as well that you can try and find with the Forum's 'Search' feature.
I was in the middle of typing a reply when you did this. Reloaded threads and I thought I lost my mind typing a reply to a thread that wasn’t there. Well time for a frosted malt beverage
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
:chug:
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
Glad the Canadian EX comes standard with a block heater.
I've plugged mine in every night and it greatly accelerates the engine warm up time.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
^^ and greatly accelerates your electric bill lol.
613GT500
Ontario, Canada
It's on a timer, set to run two hours every morning before I leave for work.
DraftEdison
Location
Iowa
16 Explorer XLT 202A AWD
Thoroughly frustrated with the Explorer! We had rain for two days and then freezing temps moved in freezing it solid so I use the remote start, let in run for almost the full 15 minutes, go outside, still can't get in and I look inside and the heat is NOT EVEN ON! How am I supposed to get in if the dang thing won't heat from the inside? Everything is set to AUTO what is going on? I won't do this for another winter it may be going bye bye soon! Ugh!
peterk9
Staff member
Moderator
Callsign
VE3
The heat is ON but it won't come on full force until you get in and turn the ignition. At that time the seats go to full heat and the blower will increase air flow. This has been discussed here several times. I believe a member stated that if you want the blower ON full then use the "last Settings" option and have the blower set to high before turning the vehicle OFF the last time you used it. If using that setting, be aware that the seats and other features that come ON with AUTO will not. In your particular situation, I doubt it would have mattered which setting you had used. Rain followed with freezing temps will usually produce the same results with most vehicles.
JR123
2016 Explorer Limited
My 2016 Limited does cool down with the remote start, you just have to give it a few. Certainly if I leave it for 2 minutes, it is cooler than it was.
DraftEdison
Location
Iowa
Getting in it and turning on the ignition defeats the purpose of remote start. The idea is that it is warm (or cool) BEFORE you get in it. It took 45 minutes for the engine to begin heating it so I could get in it. Temps were only in the 20's not below zero. I shouldn't have to set the thing on full blast every time I exit the vehicle. I would need to be physic to determine when I will need the remote start and when I wouldn't. There should be a feature where you can set the parameters for how it functions every time you use it.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
An idling vehicle on a cold day is not going to get the inside warm in 15 minutes (unless you have a block heater plugged in). When it is in "auto" mode, the blower will not turn on high until the coolant temp has reached a certain temp which is why the fan stays on low. That would be like getting in the vehicle, starting it, turning it on high and sitting there while the vents are blowing ice cold air on you. If you started the car while inside on a 20* day and started driving with it on "auto", it will do the same thing, the fan will be on the lowest setting and as the coolant temp increases, the fan temp will increase slowly. It will finally go almost full blast once the engine is warm and the air is hot.
So the vehicle is acting as it should.. not blowing air until the air is warm.
What Peter is saying is to override that and have it set at full speed so when you remote start, it doesn't do what it is supposed to... it will instead blast cold air on high until the coolant temp rises.
Not sure what else you expect, you can't have 150 degree coolant instantly on a cold day to give you heat.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
What you are doing wrong is not understanding how it all works. On remote start, you DO NOT SEE anything on the inside. There are NO lights, NO screen, NO buttons lit up BUT the system is working. When you turn the key or hit the start button (if you have push button start) to override the remote start so you can get in gear and drive off, the HVAC system reboots itself and that is when the lights and screen begin working.
But again, everything is working on remote start even though YOU CAN'T see it from the outside looking in.
ExplorerCT1080
Connecticut
2017 Sport
Can we get confirmation that as the motor heats up it will also turn the fan speed up?
I'm more concerned with the fact that the AC doesn't auto turn to HIGH when using remote start. FL summers are going to be annoying if it doesn't do it.
peterk9
Staff member
Moderator
Callsign
VE3
It will once you've turned the ignition ON. It won't if you are talking about it being in the 'Remote Start' state. Once I start driving and the engine warms up the fan speed increases dramatically.
S 2016 Explorer Remote Start - HELP Stock 2011 - 2019 Ford Explorer Discussion 6
J How to: 2016 Explorer- Adding Remote Start Facts Stock 2011 - 2019 Ford Explorer Discussion 94
H 2016 Explorer XLT Cooling and AC issues Stock 2011 - 2019 Ford Explorer Discussion 5
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
P 2016 Explorer Liftgate Panel Removal Stock 2011 - 2019 Ford Explorer Discussion 2
D 2016 Ford Explorer trans slips colder temps Stock 2011 - 2019 Ford Explorer Discussion 6
M 2016 Explorer LED signature light - only one on with ignition on Stock 2011 - 2019 Ford Explorer Discussion 8
J 2016 Explorer transmission ratting noise Stock 2011 - 2019 Ford Explorer Discussion 2
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
D 2016 Explorer Wiring Diagram Stock 2011 - 2019 Ford Explorer Discussion 6
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
R Just got 2016 explorer xlt with 20s, I have a question. Stock 2011 - 2019 Ford Explorer Discussion 11
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
T 2016 Explorer Postive battery cable replacement Stock 2011 - 2019 Ford Explorer Discussion 1
T 2016 vs 2018 Explorer purchase Stock 2011 - 2019 Ford Explorer Discussion 11
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 Explorer Sport Lemon Stock 2011 - 2019 Ford Explorer Discussion 4
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
L 3000 RPM noise 2016 explorer 2.3l Limited Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 Explorer power door lock issues Stock 2011 - 2019 Ford Explorer Discussion 7
C 2016 Explorer Limited power gate won't close Stock 2011 - 2019 Ford Explorer Discussion 5
C Best baby seat and base for 2016 Explorer Stock 2011 - 2019 Ford Explorer Discussion 7
T 2016 Explorer 4 Cyl Ecoboost Rough Idling Stock 2011 - 2019 Ford Explorer Discussion 24
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
N Ford Explorer 2016 AC not working grey out Stock 2011 - 2019 Ford Explorer Discussion 10
M 2016 Explorer Sport Tail Light Part? Stock 2011 - 2019 Ford Explorer Discussion 3
B 2016 Explorer seat mysteriously moves all the way forward Stock 2011 - 2019 Ford Explorer Discussion 20
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
P 2016 Ford Explorer Sport brake job Stock 2011 - 2019 Ford Explorer Discussion 0
H 2016 Ford Explorer Limited Speaker and Amp Upgrade - Help Sought Stock 2011 - 2019 Ford Explorer Discussion 1
H Help - 2016 Ford Explorer Limited - Won't Start Stock 2011 - 2019 Ford Explorer Discussion 3
P 2016 Explorer Hands Free Liftgate Not Working After Factory Hitch install Stock 2011 - 2019 Ford Explorer Discussion 7
M 2016 Explorer XLT PTU *PICS* Stock 2011 - 2019 Ford Explorer Discussion 35
E 2016 Explorer Parking Assist ...Ugh!! Stock 2011 - 2019 Ford Explorer Discussion 0
N 2016 Explorer. ECU location Stock 2011 - 2019 Ford Explorer Discussion 0
J Disabling interior lights in 2016 Explorer XLT? Stock 2011 - 2019 Ford Explorer Discussion 7
J 2016 Explorer XLT 4x4 turns off Stock 2011 - 2019 Ford Explorer Discussion 32
M 2016 Explorer Front End Wiring/Plug Help Stock 2011 - 2019 Ford Explorer Discussion 3
0 2016 Explorer stereo wiring diagram Stock 2011 - 2019 Ford Explorer Discussion 3
D HELP Tons of codes and Battery not keeping charge 2016 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 24
L 2016 Ford Explorer PTU Drain Plug Size Stock 2011 - 2019 Ford Explorer Discussion 7
T Brake pads for 2016 explorer - ceramic or semi metallic? Stock 2011 - 2019 Ford Explorer Discussion 35
S 2016 Ford Explorer 2nd Row Bucket Seats Stock 2011 - 2019 Ford Explorer Discussion 8
Similar threads
