Lexingtonian
- February 2, 2017
- Lexington, KY
- 2016 Exp Sport w/401a
The Master thread on this effort is located here:
http://www.diymobileaudio.com/forum...25353-2016-ford-explorer-sport-build-log.html (Update 12/24/17 thread since destroyed by the Photobucket Debacle - Not sure if I'll update that thread any longer)
__________________________________________________________________________
I've owned my Exp Sport for around 2 weeks now and have been heavily researching the Premium Sony Audio System for a buildout. I thought I'd create this thread to help others as this build will occur over the next couple months. I've had a mess of a time tracking down info on this vehicle. Oh, it's there to be found but it's all over the interwebs.
Kind of interesting in the mean time.. I certainly want a 5.1 Pro-Logic Center Channel Upmixed system (this vehicle is built for it frankly) and thus there are only 2 DSP's on the planet for Car Audio that can do that. The Alpine H800 and the JBL MS8 (now discontinued but plenty on Ebay). (there is rumor that Audio Frog is going to release something along the DSP line this year also) I'm going with the MS8 I think though. Anyway, the center channel becomes important in a system like that and I want a little more than a mincy anemic 3 1/2" speaker. I was able to confirm tonight that I can get a 5 1/4" speaker in there without too much trouble. Looking forward to the extra center audio strength. Kudos to Ford for providing the space. It should reside quite comfortably under the stock grill.
The system I'm looking to do will be as follows (subject to change):
Front Door
Tweeter - SEAS Prestige 27TFFNC
Woofer - 8" Driver Silver Flute W20RC38-04 (Stock Size is a 6x9, I like an 8" Mid Bass so some modification is required)
Center Channel
Eclipse 5 1/4" Point Source (4/30/17 may be changing to another driver, still testing) (Update, changed with the NVX V Series 5 1/4 - liked the tweet better than the old Eclipse)
Rear Door
NVX VSP60 6" Speakers (as of 12/24/17 I havent installed them yet - not sure if I will)
Rear Speakers
4" NVX VSP4
Subwoofer
JL Audio Stealthbox 10"
Sound Deadening
Noico 80 Mil (Amazon)
Amplifers
2 Soundstream Tarantula 4.900 150x4 Class D Amplifiers
1 JL Audio JX500/1D for the Sub. It's just finding a place to put them that's the tough part. Not a lot of places to hide amps in this vehicle
DSP
JBL MS8
*(Turns out, in the end, I'm not using the PAC unit - I'm using the variable line output - see Item 2 under Ford Audio Related below) PAC AP4-FD21 (Essential to connect to the CAN Bus, maintain Steering Wheel Controls and bypass the factory amp with line level signal that has been un-eq'd.
Helpful links to me at this point:
Ford Audio Related
Looking forward to adding to the thread as I get into the build (dont worry there will be Pics). I'm still ordering gear at this point but my trigger finger is getting a little, twitchy. I know quite a bit about Forscan Modification and the Audio System in the vehicle at this point. If you have questions, let me know..
- Lexingtonian
Front Door
Center Channel
Rear Door
Rear Speakers
4" NVX VSP4
Subwoofer
Sound Deadening
Amplifers
DSP
JBL MS8
Ford Audio Related
- 2016 Ford Explorer Premium and Sony Wiring Diagrams !!!!Grab This!!!!!
- Unprocessed Variable Line Out (for Sony Amp Delete)
- 2016 Platinum F150 Sony Speaker Upgrade
- 2016 Sport Audio Upgrade (thanks for your work, very helpful)
- 2015 Ford F150 Audio Upgrade
- **2014 Ford F150 w/ Sony System (very helpful thread on OEM / Factory Amp integration)**
- 2012 Limited Upgrades (Long thread full of a lot of great info - great work folks!)
- Best Custom Stealth Sub Build I've seen for Explorer (Nice work)
- The complete lack of good subwoofer options for this vehicle.. (I ain't losin' muh Spare Tire)
- PAC AP4-FD21 above in the DSP Section as it's essential for clean amplification with little factory system modification
- Door Panel Removal Guide
- JL Audio Stealthbox Install in Explorer
- Subwoofer Removal Guide
- Passenger Side Firewall Grommet Access (and Airbag Removal amongst other things..)
- Active Noise Canceling Disable (Fake Engine Noise Disable - this method is the hard way, I used Forscan and Disabled it . See the Forscan Spreadsheet Below, ACM 727-01-01)
- Forscan Software Guide
- 2015-2016 Ford F150 Forscan Spreadsheet (this thing is freaking legendary...) (Fake Engine Noise Disable on ACM Tab Line 107)
- For AsBuilt Data for your vehicle (You really should save this somewhere)
- Aux Input (Line In) Cable (I ordered the $55 kit and used Forscan to modify 7D0-02-02 in the APIM - Jason was great to work with and also offers Sync3 Upgrades amongst other things. His site primarily caters to Police Interceptor vehicles so some differences between your vehicle and those will occur)
- Forscan ODB2/CAN Bus Reader Amazon $29 (this is the one I have)
- Room Eq Wizard (REW) Tuning Primer
- Are Center Channels Relevant, here, in the future?
- Wiring Diagrams (up to 2015 - still excellent)
- Lexingtonian
