2016 Explorer Sport Front Camera Doesn't Work
Nick Hess
Iron Mountain MI
2016 Ford Explorer SPort
Any ideas with this one worked just fine and now it quit. you can push the button when your driving and it gives you this warning that it wont work unless your going slow or parked but when slow or parked nothing happens when you push the button.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Have you tried putting the vehicle into reverse and have the rearview camera come on and then putting it in Drive and hitting the front camera button to see if it works?
You can try disconnecting the battery for a few minutes, then reconnect it and see if the camera will work again. Note that you may lose some saved memory settings.
You could also try a Master Reset which will also cause some settings to change to factory default.
