2016 Explorer Technical Specs / Dimensions / Drawings | Ford Explorer - Ford Ranger Forums - Serious Explorations
JCrew7384
Jersey City, NJ
2016 Ford Explorer Platin
Hi
Is there a resrouce out there that shows the physical drawings/dimensions of parts in the Explorer? I am looking to get precise measurements of the 3rd row power fold touch panel in the cargo area...
Those details aren't in the owners manual... Need some sort of repair guide maybe?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
JCrew7384
Jersey City, NJ
The link brings me to a page which shows Explorer parts???
I am traveling for work and not home for a few weeks. It's something I want to try and design at nights on my laptop...
sheltonfilms
Hoover, AL
2013 Limited 3.5L
You will not find a drawing for that part unless you are a Ford engineer or work for the supplier that makes that part.
I have a digital caliper. Which measurements are you looking for? I hope its just the outside panel measurements as I don't want to pop my panel out.
JCrew7384
Jersey City, NJ
The width and height of the panel (as well as depth, how far the buttons stick out). Also the width of the bezel of the panel, before the buttons.
Also, is it flat? Or curved? Or at an angle? Would a rectangle box fit over it nicely if sized right?
Napalm
Memphis tn
so like said above what you're asking for is only going to be available internal to Ford production or engineering.
but I'm curious
why do you want such detail?
JCrew7384
Jersey City, NJ
but I'm curious
I want to 3D design/print a cover that will prevent unnecessary button pressing. I have almost crushed my groceries and my dog...
COscooter
Colorado! It's all downhill from here....
2016 Explorer Sport
I think it would be easier to rig a switch to turn the panel on/off
Something like this - my accent lighting is about this color. You can choose to match or not to most any color - back near the panel in a less vulnerable location...
JCrew7384
Jersey City, NJ
Perhaps... But my car is leased, so I can't make some of those modifications...
Napalm
Memphis tn
can you disable it in the options pages perhaps.
like you can the liftgate controls?
JCrew7384
Jersey City, NJ
Not that I'm aware of. I'm surprised more people don't think this is a major oversight and issue from FMC
Napalm
Memphis tn
how are you accidentally hitting these buttons?
aren't they mostly out of the way?
peterk9
Staff member
Moderator
Callsign
VE3
No way to turn those buttons off using existing features. I accidently triggered the seats while doing something in the back and the seats began to unfold with my cargo mat in place. It resulted in the left hand seat becoming dislodged from its track under the seat. I was able to free the mat and also was able to re-engage the part under the seat to get everything working again. I see no reason why Ford cannot simply install a power ON/OFF switch in the panel. I don't think the 2011 had the buttons recessed as much as they are now. But obviously it still isn't ideal.
JCrew7384
Jersey City, NJ
I have crushed groceries and almost my dog. Additionally when they start to fold or unfold, once you stop them to get them back, they don't just move back into place. They have to fully unfold to then fold up again... It's stupid that it can't just move the last piece of the way that it came from.
Napalm
Memphis tn
might be why I never wanted that feature anyway.
uhm if you wanted to disable it - temporarily, or what have you - I'd look into unplugging the seats from whatever harness is under there for the motors.
tie back the tails so they don't rattle around - and then know I can plug them back in.
just a though.
JCrew7384
Jersey City, NJ
I don't want it disabled... I am constantly am moving my seats around. I just don't want them moving if they accidentally get nudged...
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
If we all "scream" load enough, FORD should get into high gear to issue a solution...as this is definitely a safety issue.
With that being said, I have yet to accidently push any of those buttons and I tend to load and unload groceries on the opposite side of the cargo space (just a habit).
JCrew7384
Jersey City, NJ
Usually its the stroller or something large that I'm moving around the cargo area that accidentally bumps into the buttons. Not intentional ever...
I'll post what I come up with here... Maybe it will be useful to some people
Napalm
Memphis tn
maybe velcro strips - and a piece of say clear lexan or something you can get at lowes/home depot
say the switch panel is 2 inches by 3 - then you make something 2.5 by 3.5 and use some strips of self adhesive velcro to the area around the panel.
or just the top and bottom maybe
and you have a easily removable cover so you can get to the button - but it's also significantly less noticeable when covered. (being clear and against a black backgroud)
