2016 Ford Explorer rattle
altasteven
San Marcos, ca
2016 Ford Explorer xlt
Just got a 2016 Ford Explorer XLT. I have realized that doing freeway speeds I have a rattle of some sort coming from the driver side. Doesn’t affect anything at all is just annoying like something loose inside the dash. Maybe under the cluster panel? Anyone had this issue before I go taking everything apart? I have a video but can’t figure out how to post it. Maybe I’ll do a YouTube link later? It is also not the ac or radio. I turned both off. Sounds like a loose bolt or washer or something!
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
Does the noise increase and decrease depending on the speed you're driving? if so, it could be the cowl that is loose. Several members have reported issues with it. Ona 2016, I doubt that it would be the 'A' pillar. Sounds can be very difficult to pinpoint.
altasteven
San Marcos, ca
I would say yes it does increase. I only hear it at about 65+ and it is more constant if I do 75-80. When passing. Where is the cowl located? 😅
altasteven
San Marcos, ca
Here’s the best I could do. Sorry about the road noise but the “sound” you hear is louder in person. I did tape the cowl like others say to do but the sound was still very present.
altasteven
San Marcos, ca
Now let’s say it was the “a” pillar. Is that a repair or do I replace the whole thing? Is there some way to stop the noise at all without replacing it. IF it was that
peterk9
Staff member
Moderator
Callsign
VE3
If it was the 'A' pillar than it is likely that some clips my have broken. If that is the case, you have to replace the whole thing including the clips. Before doing that, I suggest doing the same thing as the cowl by taping it. Explorer 'A' pillar replacement
Odrapnew
MN
2014 Explorer Sport
It's hard to tell where it's coming from, but any chance it's the air freshener in the side vent?
Does it sound like it's coming from up near the a-pillar?
Might want to start grabbing, pushing, pulling things around the dash to see if you can get it to go away.
altasteven
San Marcos, ca
It wasn’t the air freshener. It was happening before hand. It sounds like it’s coming near the bottom left of the front windshield. I can’t say if it’s from inside or outside but it most definitely is near the driver side right near the glass I would say!
whimsey
sparta, nj
2017 XLT
Our 2017 XLT has the same rattle location. Ours rattles more the faster you go. I'm thinking it's most likely from the cowling molding. At 57,000 miles it developed a new rattle in the drivers door. Plus there are other rattles in the vehicle, none that are super annoying enough to pay to try to have them try to be taken care of. Chances are they'll make thing worse by chasing after the rattles. Our 2005 Explorer with 198,000 miles is rattle free, always has been.
