2016 Ford Explorer Sport, Passenger floorboard completely flooded
CGiunta
San Jose, CA
My local San Jose dealership is having trouble finding where water is coming inside my 2016 Ford Explorer Sport. They've had the vehicle for 11 days now. Any suggestions on how to handle this situation? My warranty is expired but I do have 100K mile service warranty. Only 44,000 miles on my Explorer.
Thanks
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
The most common cause for water in the foot wells is a blocked or disconnected moonroof drain.
If you pour water onto the roof, the line on the passenger side should drain the water by the front right wheel.
Check out the pictures here; Wet carpet Second Row
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Be prepared.. water leaks are not covered outside the b2b warranty.
CGiunta
San Jose, CA
Appreciate the response. Thanks!
ncsuengineer256
2014 Explorer Limited
I had this issue. Sure enough, the front drains were clogged with tree bark / acorn chunks. I cleaned both front drains and haven't had an issue since. Hope that helps.
CGiunta
San Jose, CA
Appreciate the response. It turned out to be the sunroof drain was clogged.
whimsey
sparta, nj
2017 XLT
Our 2017 XLT developed a leak into the vehicle, coming down the front passenger seat belt. Had the sun roof drains "cleaned" by the dealer during the 3/36 warranty. A year later it happened again, no warranty this time. Cleaned the front drains from the top and the rear drains from the exit as you can't reach the rears from the top without removing a lot of stuff. Tested it with water in the sun roof channels and it drained out all the drains, front and back. Closed the sunroof for the season at that time and haven't opened it. It was fine through rain and snow afterwards, until recently. A wind driven rain caused it to leak again :(. I'm thinking it's coming in through the roof rack bolt holes when the conditions are right. I'll check that out in the spring.
Whimsey
peterk9
Staff member
Moderator
Callsign
VE3
The most common area that the roof rack leaked was in the rear where water ran down the 3rd row seat belt.
CGiunta
San Jose, CA
Not good! Just poor design and quality. My dealership recommended getting a waterproof cover so it doesn't happen again? WTF?
Has anyone who experienced a leak in their vehicle also has seen a puff of hot steamy air (inside front windshield) during some passing gear throttle situations? I've been having this problem for at least 2 years (under warranty) and even the service manager at my local dealership said it's related with water getting inside the vehicle. Ford refuses to see the connection? Very disappointing!
peterk9
Staff member
Moderator
Callsign
VE3
......Has anyone who experienced a leak in their vehicle also has seen a puff of hot steamy air (inside front windshield) during some passing gear throttle situations? I've been having this problem for at least 2 years (under warranty) and even the service manager at my local dealership said it's related with water getting inside the vehicle. Ford refuses to see the connection? Very disappointing!
This issue has not been posted about before.
Adrian Gitch
Paris, KY
2015 Explorer Limited
What you might be seeing is when u gun it, on most newer vehicles the compressor will disengage so it temporarily affects the climate control. Sudden change in temperature on windshield could be the cause but then again I haven’t paid attention if mine does it. May very well be the moisture in yours from the leak.
T Spad
Connecticut
2016 Explorer Sport
I had the same exact issue in my 2016 Sport. Dealer claimed it was an open body seam inside the fender. I am not so sure that was the case.
I believe the RF drain hose was blown off the sunroof pan drain by the high velocity dryer. I would say your issue is 99% related to the sunroof drain tube.
