2016-Need to calibrate blend door actuator after replacement
DBAIN
MO
2016 Explorer Sport
Hi, I replaced my blend door actuator in my 2016 sport a couple months back. It worked, but the actuator seemed to ignore the limits of the damper and kept trying to open or close further, eventually causing a gear tooth to break in the actuator. How do I reset the system after replacing the actuator, so that it knows the limits and stops when it's supposed to?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
There have been several actuators replaced but I can not recall anyone mentioning any calibration was required.
S Need advice - 2017 Explorer or 2016 Expedition Stock 2011 - 2019 Ford Explorer Discussion 9
D Need fobs for door locks 2016 pd explorer Stock 2011 - 2019 Ford Explorer Discussion 8
L 2015 or 2016 Ford Explorer. Need your opinion please! Stock 2011 - 2019 Ford Explorer Discussion 22
M 17s with bigger tires on 2016 Sport?? Stock 2011 - 2019 Ford Explorer Discussion 2
H 2016 XLT Stalled and Wont Start Stock 2011 - 2019 Ford Explorer Discussion 1
H 2016 XLT Driver Side Grounding Strap Stock 2011 - 2019 Ford Explorer Discussion 2
T Has anyone modified their 2016+ so they can turn off their headlights? Stock 2011 - 2019 Ford Explorer Discussion 9
T Options for replacing LED low beams 2016+ Stock 2011 - 2019 Ford Explorer Discussion 4
H 2016 Explorer XLT Cooling and AC issues Stock 2011 - 2019 Ford Explorer Discussion 5
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Sport drops power or boost under load Stock 2011 - 2019 Ford Explorer Discussion 2
P 2016 Explorer Liftgate Panel Removal Stock 2011 - 2019 Ford Explorer Discussion 2
D 2016 Ford Explorer trans slips colder temps Stock 2011 - 2019 Ford Explorer Discussion 6
N Ambient Air Temp Sensor Replacement 2016+ Stock 2011 - 2019 Ford Explorer Discussion 1
J 2016 Limited Rear Brake Pads Stock 2011 - 2019 Ford Explorer Discussion 7
M 2016 Explorer LED signature light - only one on with ignition on Stock 2011 - 2019 Ford Explorer Discussion 8
S 2016 2nd Power Point Stock 2011 - 2019 Ford Explorer Discussion 1
M REAR BACK UP SENSOR 2016 XLT Stock 2011 - 2019 Ford Explorer Discussion 1
J 2016 Explorer transmission ratting noise Stock 2011 - 2019 Ford Explorer Discussion 2
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
D 2016 Explorer Wiring Diagram Stock 2011 - 2019 Ford Explorer Discussion 6
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
J 2016 Sport Wiring Issue? Stock 2011 - 2019 Ford Explorer Discussion 2
R Just got 2016 explorer xlt with 20s, I have a question. Stock 2011 - 2019 Ford Explorer Discussion 11
J 2016 Explorer 2.3 Ecoboost Idle Issue Stock 2011 - 2019 Ford Explorer Discussion 11
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
J 2016 keypad entry Stock 2011 - 2019 Ford Explorer Discussion 0
T 2016 Explorer Postive battery cable replacement Stock 2011 - 2019 Ford Explorer Discussion 1
W 2016 2.3 fwd rpm hunting Stock 2011 - 2019 Ford Explorer Discussion 3
T 2016 vs 2018 Explorer purchase Stock 2011 - 2019 Ford Explorer Discussion 11
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
C Door handle 2016 Stock 2011 - 2019 Ford Explorer Discussion 1
S 2016 blowing AC clutch relay fuse #16 Stock 2011 - 2019 Ford Explorer Discussion 2
B 2016 XLT ecoboost (non sport) Shuts off while driving Stock 2011 - 2019 Ford Explorer Discussion 4
S 2016 Ex Passenger Door Unlocking and Alarming with No Keyfob Stock 2011 - 2019 Ford Explorer Discussion 0
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 sport throwing p0327 code Stock 2011 - 2019 Ford Explorer Discussion 1
S Slow Start Long Crank 2016 XLT Stock 2011 - 2019 Ford Explorer Discussion 6
Sentry6 Sony control panel, touch panel upgrade to 2016 -19 style Stock 2011 - 2019 Ford Explorer Discussion 1
A 2016 Ford Exploer Sport LED Foglights Stock 2011 - 2019 Ford Explorer Discussion 2
U Contribute your experience: Ford Explorers 2016-2019 Stock 2011 - 2019 Ford Explorer Discussion 11
M 2016 Explorer Sport Lemon Stock 2011 - 2019 Ford Explorer Discussion 4
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
L 3000 RPM noise 2016 explorer 2.3l Limited Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 Explorer power door lock issues Stock 2011 - 2019 Ford Explorer Discussion 7
Similar threads
