2016 PIU flashing parking lights | Ford Explorer - Ford Ranger Forums - Serious Explorations
opd1653
San Francisco CA
2020 Ford PIU
Hi All:
First, like to thank all for the information about these vehicles. I have a 2016 PIU with the following issue:
With the ignition on: Headlights turned on, parking lights will flash rapidly, turn signs will operated normally,
With the ignition off: Headlights turned on, parking lights will light normally, no flashing. Turn signals will operate normally.
The 2016 has the optional pocket warning light option. After some research, I found Ford SSM 46858 2016-2017 Police Utility - Front Amber Marker Lamps Flicker Only With the Engine Running.
Is this something only the IDS can fix? Can Forscan be utilized, if so, what needs to be changed?
Thanks,
Al
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Al.:wave:
opd1653
San Francisco CA
2020 Ford PIU
Thanks, I took it to dealer and they changed the frequency of the headlight unit to "2" . Problem solved all pending recalls done under warranty.
