Chris Washburn
- April 23, 2018
- Spokane, Wa
- 2016 Explorer XLT
Hey guys,
I am needing to remove the driver seat to install a DSP under it. When I started looking at it, it looks like there are only two bolts in the front and the rear support is mounted under the center console on the in board side and to a bracket with a shock that is part of the seat belt system on the outboard side. So, I have a few questions:
1.) Do I have to pull the center console to remove the seat
2.) Will removing the seat cause an airbag code to hit
3.) Can I just unbolt the out board bracket or will that cause a problem with the seat belt?
Any help appreciated,
Chris
Chris
