firefourninety
- March 2, 2019
- NJ
- 2017 EXPLORER BASE MODEL
My 2017 anytime the temperature goes below freezing does not start.
When I open the door, there is no chime, the dashboard screen and radio screen are off. There is no turn over. There is no chime when I put the key in. There is literally no sound or response from the car in any way when I turn the key. Complete silence lol.
However the headlights can be turned on and off. You can flash the high-beams. the locks cycle. even the remote can lock/unlock the doors and the confirmation "honk" when locking works, and the horn works too. So the car does have electricity.
Once the car warms up after a few hours, as the sun hits it or as the day gets warmer, the car operates and behaves perfectly normal.
This is the base model of the 2017 so it did not come with the remote start feature. This was installed a while after I got the car at the dealership. It also does not start using the remote start. the car honks to confirm and nothing happens.
The starter has been replaced, I've been given multiple batteries including a stronger ones, I've had the fuel injector also replaced. This happens every winter and my dealership can never solve and tells me it didn't do that and started right up for them... I believe this is because the car had time to warm up before they got to my car that morning/afternoon.
Any info would absolutely help!
I've been trying to solve this issue for years!!
Thank you!!
Thank you!!
