2017 Explorer 20in sport wheels on 2010 Ford Explorer Sport | Ford Explorer Forums - Serious Explorations
Spencer Woodring
Waynesboro, PA
I was wondering if with the 2017 Ford Explorer sport 20in wheel set up is the same tire specs as my 2010 Ford Explorer with 20in wheels if I was able to use those wheels on mine. It looks like they have the same bolt pattern and can fit the same tire the only difference if the offset.
You might want to check the center hub diameter to make sure they are compatible.
