2017 Explorer D.I.Y. Remote Start..
WilliamNC
NC
2017 Explorer
Hello all...So my wife and I just bought a new 2017 Ford Explorer XLT..with I believe the 200A equipment package,so a remote start was not included..
I ordered 2 parts from the Ford dealership;
Part no.FT4Z-19A361-A
(Electronic Module)
Part no.EL3Z-19G364-B
(Kit-Remote)
Well now I have an installation scheduled at the dealership for Jan4..and I sure would like to save a few hundred dollars and install the system myself...
Here is what i know...
This is a plug-n-play kit
The system will also require a hood switch..which i would just assume bypass..or have bypassed..
Here is what im not so sure about..
Because of the keyless entry/keyless ignition...the computer may have to be reprogrammed to allow the engine to start
without a fob inside of the vehicle..
Soooo....does anyone know if i can install the parts myself and just have the dealership do the programming for me..and could i do the programming?..is it even necessary?..I thank anyone with some knowlageable feedback on this issue..Thanks!
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
(Electronic Module)
(Kit-Remote)
Yes you can install yourself, I have done the full VSS and RMU kit myself, so have many others.
The only difference is because your vehicle doesn't have factory initialized remote start your dealer must use their IDS tool and go into BCM and turn that feature on.
There are several really good threads here for this install with pictures, just use search feature.
WilliamNC
NC
2017 Explorer
Well thank you for your reply..but i have not just searched this website..whose search engine is powered by google...but i have searched google before i signed up here..and nowhere have i seen any info regarding the 2017 install...now after seeing your response i immediatly searched "remote start install 2017 explorer"....the exact same results appeard when i searched "remote start install 2016 explorer".. now granted it said there were a bit over 3,000 threads...i only looked at the first 10 maybe...if you have a link that would be very cool...or maybe am i just to assume that the 2017 plug n play is the exact same as 2016...because i do know that 2016 is completely different then 2015 and previous year models...ya...i do not see A SINGLE refrence to a 2017 install...like anywhere...thats why i posted this...thank ya much though
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
As requested, please add the trim level of the Ex to your profile. Thanks.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
PM me with an email I will send you the 2017 Installation Guide from Ford
WilliamNC
NC
2017 Explorer
Sorry about that..You were right about me omitting information about my vehicle on profile page....I only had entered "2017 Ford Explorer"...after reading your reply..i went and looked..it does ask for year...MAKE and model...so I added that i have an Explorer made by Ford...and even though it does not ask for the trim...I added that my vehicle is an XLT....like i wrote in my original post....thanks for catching my error..
WilliamNC
NC
2017 Explorer
Thank you very much Sgt1411..I just today recieved the 33 pages from Ford with the heading :
2017 Explorer. Vehicle Security/Remote Start/Remote Access
I really do apreciate your offer to help...:thumbsup:
I plan on intalling the system this coming Sunday...now if you have a Rotunda and the IDS software for the programming portion.....then I would be on Easy Street....i dont expect hiccups nor failure..but just for closure...ill post when the remote works ;)
peterk9
Staff member
Moderator
Callsign
VE3
If you look at the Terms and Rules you will see that it states. "Since there are so many configurations of the Explorer, it makes it hard to be able to answer questions when the year and model aren't mentioned." When it says "so many configurations of the Explorer" I take that to mean Base, XLT, Limited, Sport or Platinum. Each has its own configuration and if that trim isn't shown in the profile which puts it in the margin, then members won't know which one you are referring to as some trims may have unique issues and features. I'll ask the Admin to see if he can clarify the terminology.
Just check out the other posts and you will see that the majority show that information and the members don't have to mention which they have every time they post.
Lewisra
Howell, mi
2017 explorer limited
You MAY be able to do the activation yourself with Forscan. Check out his link:
http://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/
peterk9
Staff member
Moderator
Callsign
VE3
Problem solved. When filling out your profile you will now be asked to add the "trim level". Thanks to the site Admin.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
I love it when people just put 20?? Ford Explorer.......as opposed to what, the GMC or Nissan Explorer?
Jeff118
South Jersey
2017 Explorer XLT
WilliamNC , how did you ever make out with this?
Jeff118
South Jersey
2017 Explorer XLT
If you look at the instructions for installing FT4Z-19A361-A and DL3Z-15603-C in a 2016 and 2017 Explorer, the instructions show that the IDS programming is only needed for key start vehicles, that the IDS steps are to be skipped over for push start IAK vehicles.
zepeda3252
Mission Hils, CA
2020 Explorer XLT
Any one have the guide for the new gen? I bought a 2020 xlt with no remote start fob key, but I can emote start from my phone. I am not trying to pay 500$ for installation.
peterk9
Staff member
Moderator
Callsign
VE3
Have you read the thread on adding remote start in the 6th gen. Forum?
peterk9
Staff member
Moderator
Callsign
VE3
Go to the top of this page and click on "Search". Then select "Advanced search". On the next page select "Search threads" and in the keywords ae area type in "adding remote start". Then scroll down to "search in forums" and chose 2020+ Explorer - 6th Generation - Lincoln Aviator and then scroll down and select "Display results in threads" and click "search".
zepeda3252
Mission Hils, CA
2020 Explorer XLT
Located, thanks!
peterk9
Staff member
Moderator
Callsign
VE3
The 'Search' feature is a handy tool. Not sure if that thread will help much though.
R Can I Replace 2013 IPC (Cluster) With a 2017? 2011-2016 My Ford Touch / In Vehicle Technology 5
D 2014 Explorer Limited Cannot use both USB ports at the same time 2011-2016 My Ford Touch / In Vehicle Technology 5
C 2013 Explorer Rearview Camera Issue 2011-2016 My Ford Touch / In Vehicle Technology 3
S Adding One Touch to rear windows 2018 Explorer Sport? 2011-2016 My Ford Touch / In Vehicle Technology 5
J 2013 Ford Explorer XLT - Controls not working 2011-2016 My Ford Touch / In Vehicle Technology 9
M 2016 Explorer Limited - Front USB ports not working 2011-2016 My Ford Touch / In Vehicle Technology 13
P 2011 Explorer XLT APIM issues 2011-2016 My Ford Touch / In Vehicle Technology 1
iTonyp Sync 3 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 2
E 911 Assist Fault Explorer 2013 2011-2016 My Ford Touch / In Vehicle Technology 12
N 2016 Explorer Sport Front Camera Doesn't Work 2011-2016 My Ford Touch / In Vehicle Technology 1
D 2011 Ford Explorer Sync 2 replacement 2011-2016 My Ford Touch / In Vehicle Technology 2
R 2013 Explorer Sport Cruise Control 2011-2016 My Ford Touch / In Vehicle Technology 21
S 2012 explorer cross traffic fault blind spot fault 2011-2016 My Ford Touch / In Vehicle Technology 1
J 2015 Explorer Sport - upgrading Sync 2 to Sync 3 - have few ?'s 2011-2016 My Ford Touch / In Vehicle Technology 14
M 2013 Explorer - Left Information Display - White with black lines 2011-2016 My Ford Touch / In Vehicle Technology 15
S Issue with 2015 Ford Explorer Key Fob 2011-2016 My Ford Touch / In Vehicle Technology 3
N 2012 Explorer XLT Keyless Entry Inoperable 2011-2016 My Ford Touch / In Vehicle Technology 4
W 2011 Explorer XLT - Radio Problems 2011-2016 My Ford Touch / In Vehicle Technology 2
A Aftermarket 12.1" Android Navigation Radio for Explorer 2011-2016 My Ford Touch / In Vehicle Technology 4
J 2013 Ford Explorer message 2011-2016 My Ford Touch / In Vehicle Technology 8
P Upgrading 2016 Explorer to Sync 3 - FORScan questions 2011-2016 My Ford Touch / In Vehicle Technology 28
G Software updates for 2014 Explorer XLT 2011-2016 My Ford Touch / In Vehicle Technology 1
K Another Explorer Navigation Error 2011-2016 My Ford Touch / In Vehicle Technology 9
A 2011 Explorer APIM Question 2011-2016 My Ford Touch / In Vehicle Technology 3
F 2013 Explorer Media Interface Question. 2011-2016 My Ford Touch / In Vehicle Technology 5
K Newbie to the Explorer forum question 2011-2016 My Ford Touch / In Vehicle Technology 8
K 2013 Ford Explorer 200 Plug In Play Remote Start Key Fob not working 2011-2016 My Ford Touch / In Vehicle Technology 4
J Issue with Sync in 2011 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 14
A Radio wiring diagram for a 2013 Explorer XLT 2011-2016 My Ford Touch / In Vehicle Technology 14
S Add (after market) Collision Avoidance to 2015 Explorer Sport 2011-2016 My Ford Touch / In Vehicle Technology 3
G Android screens for ford explorer 2011-2015 2011-2016 My Ford Touch / In Vehicle Technology 3
G Ford Explorer 2015 XLT additional key 2011-2016 My Ford Touch / In Vehicle Technology 2
L 2013 ford explorer sport headrest DVD. HELP! 2011-2016 My Ford Touch / In Vehicle Technology 2
G Installing Backup Camera and 8" Screen in my 2013 Explorer - Is it possible? 2011-2016 My Ford Touch / In Vehicle Technology 3
H Location of 2013 Explorer Service Button 2011-2016 My Ford Touch / In Vehicle Technology 14
J SYNC 3 in a 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 259
J Siri and XM Radio Questions - New 16 Explorer Platinum 2011-2016 My Ford Touch / In Vehicle Technology 8
M 2012 Explorer USB Ports 2011-2016 My Ford Touch / In Vehicle Technology 1
G Buying a 2012 Explorer - Nervous about MFT Issues (please advise) 2011-2016 My Ford Touch / In Vehicle Technology 7
R 2011 Explorer XLT alarm issue 2011-2016 My Ford Touch / In Vehicle Technology 0
D 2015 Explorer Sport - Intermittant no-start with push button start 2011-2016 My Ford Touch / In Vehicle Technology 21
S Installing a Blackvue in a 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 9
P 2016 Ford Explorer and Remote Climate Control 2011-2016 My Ford Touch / In Vehicle Technology 2
J 2016 Explorer with MFT - Add Climate Control to Instrument Cluster 2011-2016 My Ford Touch / In Vehicle Technology 25
J Add HD Radio to your Explorer 2011-2016 My Ford Touch / In Vehicle Technology 1
M 2013 Explorer Security & Remote Starter Options 2011-2016 My Ford Touch / In Vehicle Technology 16
J MFT SYNC 3.8 SIRI Eyes Free - Avail. on SYNCMYRIDE.COM for 2011-2015 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 330
S 2016 Ford Explorer Sport TPMS Part# 2011-2016 My Ford Touch / In Vehicle Technology 34
K Ford Explorer Wifi 2011-2016 My Ford Touch / In Vehicle Technology 14
S Does Explorer 2012 XLT have Navigation? 2011-2016 My Ford Touch / In Vehicle Technology 5
Similar threads
