Elfiero
- September 4, 2018
- Golden valley, MN
- 2017 Limited
Yesterday I changed oil in my PTU for the first time. First thing I noticed was it had no drain plug. So, I quickly went to youtube for a solution. I added a drain plug 1" to the rear of the bottom-most bolt "reenforcement", and 2" to the right of the parting line of the case haves. that put the hole almost perfectly under the "Y" in the exhaust pipes. The case is about 1/2" thick at that point, so there is plenty of meat for threading it 1/4"NPT. The oil was very brown- but no sludge yet. I removed the level plug from the side(not easy) and there wasn't a whole lot of metal on it yet. I did the extended vent hose, and tied it off to the side of the brake master cylinder. I refilled it with 90w140 full synthetic Valvoline until it ran out of the bottom of the side fill plug hole. It took approximately 16 ounces. I am going to repeat this process next spring, and then every fall after that. Once you have a drain plug, it's a piece of cake!
