raysocal
- August 20, 2016
- 2017 Explorer
I don't know why Ford changed the rack rails for 2017 by putting on a black plastic base that fills in completely the space under the rail?! This prevents using a tie-down to wrap around the bars because there is no way to pass a strap under the bar.
This design also prevents use of a Yakima clamp to fit around the side rail bar. I contacted Yakima and Thule and they have not figured out how to fit their rack yet. I thought someone here may have figured something out. Can the plastic under the bar be removed and the side rails still work? It does not look possible because it is all one piece with the base.
