2017 Transmission Issues
GregoryKi
MCKINNEY, TX
2017 Explorer XLT
Hi all, new member with a quick question.
I have a 2017 Ford Explorer XLT (V6) with ~19,000 miles that started to leak transmission fluid from one of the hose seals. I took it to the dealer and they think that the line to the cooler is clogged or the solenoid is not working which caused the seal to bust when the fluid overheated and caused overpressure. It is still at the dealer and they will let me know more after the teardown of the transmission.
I searched around and this didn't seem like a common issue. The service tech mentioned that they only seen this a couple of times. My question is has anyone else heard of this issue? My wife drives the car around town with our kids, so there shouldn't be too much stress on the vehicle.
Thank you,
GK
03WIExplorerLtd
2011 Explorer FWD base
Clunky, but reliable are the 6f5x transmissions
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Gregory.:wave:
GregoryKi
MCKINNEY, TX
2017 Explorer XLT
Thank you, a lot of helpful information on here.
Haven't heard from the dealer on the status yet, with Labor Day weekend, but will post on what they find out.
GK
GregoryKi
MCKINNEY, TX
2017 Explorer XLT
Update from the repair:
The issue was that the converter seal was leaking (transmission) in addition to the rear main seal retainer (oil). Luckily the transmission case was not warped.
They are not sure why the seal start leaking, only seen this happen a couple of times before with this model.
GK
E 2017 XLT Transmission Leak Stock 2011 - 2019 Ford Explorer Discussion 0
N 2017 XLT 2.3 transmission failure Stock 2011 - 2019 Ford Explorer Discussion 61
9 2017 Explorer Sport Transmission Type Stock 2011 - 2019 Ford Explorer Discussion 9
W 2017 Explorer Sport - Rumbling when when turning. Stock 2011 - 2019 Ford Explorer Discussion 6
S 2017 Explorer XLT 3.5L AWD Stock 2011 - 2019 Ford Explorer Discussion 1
C Vibration at highway speeds - 2017 XLT Stock 2011 - 2019 Ford Explorer Discussion 4
R 2017 cross bar bolt size Stock 2011 - 2019 Ford Explorer Discussion 8
T 2017 Ford Explorer - Exterior trim pieces in horrible shape Stock 2011 - 2019 Ford Explorer Discussion 2
B 2017 Platinum interior lights question Stock 2011 - 2019 Ford Explorer Discussion 1
A 2017 Explorer XLT Overdrive Stock 2011 - 2019 Ford Explorer Discussion 3
W Disable front parking aids 2017 explorer Stock 2011 - 2019 Ford Explorer Discussion 2
M 2017 Explorer - Fuel Gauge Above Full Stock 2011 - 2019 Ford Explorer Discussion 1
J What happened to my 2017 Explorer Sport??? (Turbo and Engine issues) Stock 2011 - 2019 Ford Explorer Discussion 11
S Cracked leather - 2017 Limit Stock 2011 - 2019 Ford Explorer Discussion 5
ISTGradFromPSU 2017 Explorer Driver Side Massage Seat Issue Stock 2011 - 2019 Ford Explorer Discussion 4
C New Member 2017 Explorer XLT - Stability Control? Stock 2011 - 2019 Ford Explorer Discussion 4
T Looking at 2017-2018 limited explorers Stock 2011 - 2019 Ford Explorer Discussion 3
S 2017 Passenger side mirror glass issue Stock 2011 - 2019 Ford Explorer Discussion 6
R 2017 Explorer Sport 2nd row console Stock 2011 - 2019 Ford Explorer Discussion 7
C 2017 Sport White/Blue Smoke on Startup/Acceleration Stock 2011 - 2019 Ford Explorer Discussion 10
J Issue with 2017 Explorer XLT. Looking for advice or opinions Stock 2011 - 2019 Ford Explorer Discussion 3
F 2017 Explorer Sport takeoff surging Stock 2011 - 2019 Ford Explorer Discussion 8
H Signature Lighting operational on 2017 base model? Stock 2011 - 2019 Ford Explorer Discussion 1
P 2017 Ford Explorer Limited drivers side LED fog light has quit working Stock 2011 - 2019 Ford Explorer Discussion 2
B 2017 Water Pump? New to Ford forum. Stock 2011 - 2019 Ford Explorer Discussion 16
D Looking at a 2017 Explorer Platinum Stock 2011 - 2019 Ford Explorer Discussion 6
T 2017 Explorer drivers door unlock issue Stock 2011 - 2019 Ford Explorer Discussion 3
M 2017 Explorer brake controller Stock 2011 - 2019 Ford Explorer Discussion 5
S Key on power for aftermarket seat heaters in base 2017 explorer Stock 2011 - 2019 Ford Explorer Discussion 1
S 2017 Base Explorer aftermarket remote start install Stock 2011 - 2019 Ford Explorer Discussion 4
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
M 2017-up 3.5: PTU or water pump failures Stock 2011 - 2019 Ford Explorer Discussion 3
T 2017 Explorer Platinum PTU help needed Stock 2011 - 2019 Ford Explorer Discussion 0
B Noobie with an issue 2017 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 13
5 Can a 2017 Limited have 401a package? Stock 2011 - 2019 Ford Explorer Discussion 4
Y 2011 looking at 2017 rims TPMS question Stock 2011 - 2019 Ford Explorer Discussion 1
S 2017 Explorer Sport shifting hard Stock 2011 - 2019 Ford Explorer Discussion 5
D 2017 Sport Possible oil leak? Should I be concerned? (pics) Stock 2011 - 2019 Ford Explorer Discussion 10
G $$$ Dollar Value of 2017 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 5
M Turning indicator light (2017) sometimes does not work Stock 2011 - 2019 Ford Explorer Discussion 2
T 2017 Explorer Push Retainer Bumper Part Stock 2011 - 2019 Ford Explorer Discussion 3
G 2017 explorer low beam fuse location Stock 2011 - 2019 Ford Explorer Discussion 2
D 2017 Ford Explorer Sport stock exhaust Stock 2011 - 2019 Ford Explorer Discussion 10
W 2017 XLT Tail Light help. Stock 2011 - 2019 Ford Explorer Discussion 1
edwx Does my 2017 Explorer have a cabin air filter? Stock 2011 - 2019 Ford Explorer Discussion 6
D New Member 2017 Explorer 4x4 question Stock 2011 - 2019 Ford Explorer Discussion 5
J 2017 explorer sport tire size Stock 2011 - 2019 Ford Explorer Discussion 14
E Safety Technology in 2017+ Explorers Stock 2011 - 2019 Ford Explorer Discussion 6
I 2017 explorer front right axle leak Stock 2011 - 2019 Ford Explorer Discussion 14
B Picked up 2017 Sport-Thoughts So Far Stock 2011 - 2019 Ford Explorer Discussion 4
Similar threads
