2018 Remote start and Climate Control
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
New 2018 Explorer XLT, remote start works as it should... But climate control does not keep vehicle temp. We use remote start to keep the vehicle temps comfortable for our dog when we run into a store, but fan blows but no cool. Any ideas?
sheltonfilms
Hoover, AL
2013 Limited 3.5L
What’s the outside temp and your requested temp? I’m assuming the vehicle is already cooled down when you do this based on how you are using it.
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
Usual outside temps in Alabama are in the mid 90's, temp control is set to 70. Vehicle is comfortable before using remote start.
15min set run time, vehicle is probably around 95, fan is blowing hard, but no AC
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Set to auto or last for the remote start climate control?
sheltonfilms
Hoover, AL
2013 Limited 3.5L
What he said. Plus is your ambient temperature showing correctly on the dash?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the FOrum Tom.:wave:
I'm not sure how the keyed ignition works but when starting a push button start Explorer with remote start and the setting on 'Auto', the fan will not blow full blast until such time as you get in and put your foot on the brake and push the start/stop button. Only then will the fan increase speed. This applies to A/C and heat. Up to that point, the fan just runs at a low speed.
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
It is a new 2018 Explorer, push button start, tried Auto and last setting on remote climate control. Same with both, just blows hot air at the highest fan speed.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
Does it every time? Should be easy to show to a technician. Just take it to the dealer. Unless you are trying to fix it yourself.
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
Just wanted to make sure I wasn't doing something wrong, just made a service appt.
Thanks to all!
bigtexan99
2016 Explorer Sport
Can you explain why you need to 'remote start'? If you stop at a store and run in for a minute, why would you turn the car off or need to remote start it? Just leave it running.
Also, if you are going to do this on a regular basis suggest you search the forum for the FORSCAN hacks and enable the "police idle". It locks the transmission in park if the key fob is not within a few feet of the car. That way if someone was to smash your window and try do drive off they would not be able to shift the car into Drive.
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
The remote start is just like most premium remote starts, it give the owner the option of starting the vehicle and letting it run to warm up on a cold morning or to keep the vehicle cool on hot days.
As a new Explorer owner, I have to presume that unless the keyfob is in the car it cannot be driven(shifted into gear), not sure where you live 'bigtexan99' but even here in Alabama it is not a good idea to just leave a car running and go into a store(although with a 100lb dog it probably doesn't matter)
bigtexan99
2016 Explorer Sport
Ah, so you are turning off the vehicle and then 'remote starting' it for the air and so that it can't be driven off without the key fob.
One other thing to try is set the AC to MAX right before you turn it off (with the instrument panel option set to "last setting, not auto") and then when you remote start it that's going to be about as cold as it gets.
After you have exhausted all your options, spent time at the dealer, and read all the threads here about how the AC operates in some sort of a 'limp mode' with remote start (which is super annoying in hot Texas), re-read my suggestion on FORSCAN, Police Idle, and just leave the car running so your dog does not die. That's how I do it.
Cheers!
peterk9
Staff member
Moderator
Callsign
VE3
False assumption. The vehicle can be driven away without the keyfob being in the area. In fact a member reported such a thing happening when drivers were switched when the vehicle was running only to find out after the second driver turned the vehicle off that it could not be started. Also, FYI, the vehicle can be restarted without the fob if it attempted within 20 seconds of turning it off.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
It's what @bigtexan99 was getting at. Factory setting on civilian vehicle does allow car to be driven when key isn't detected. Modifying the coding of the car to enable Police Idle adds the logic that the key has to be in the vehicle for the shift interlock to release.
I've pulled out of my driveway plenty of times with the "KEY NOT DETECTED" message because I had the keys in my left pocket and the fob battery was getting low.
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
Just to let everybody know... Had my appointment at the local Ford dealer yesterday.
Yes, they know about the problem, it has been reported and verified numerous times, but Ford does not have a fix for the problem,
They are supposed to notify me when it is available.
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
What's the "problem"?
Is it affecting all 2018 EX or all 2018 vehicles with autostart?
Tom(North Alabama)
Madison, Alabama
2018, Explorer XLT
The problem(as described) the climate control does not work when using Remote Start, apparently 'all ' Explorers are not affected
613GT500
Ontario, Canada
I wouldn't accept that answer and suggest you try a different dealership.
Has to be software related and you may need a re-program or a new APIM.
MrPlat
Mills River, NC
2018 Explorer Platinum
Did you ever get a fix? I've noticed that in my 2018 the rear AC doesn't turn on until I get in and press the start button. I haven't thought to make sure it is blowing cold air before I start the vehicle. It is a real bummer since the point of remote starting the car is that I have AC blowing on my kid in a car seat while I'm getting her buckled in and walking around to the driver seat.
MrPlat
Mills River, NC
Well, I disabled the Auto control of the remote start HVAC and set it to Last Setting. This makes the rear blow cold AC when remote starting. Kind of a bummer, but I'll just be sure to not turn off the HVAC if I know I'll need to remotely cool/heat the car the next time I hop in.
J Change in 2018 remote - no LED to indicate Remote Start Stock 2011 - 2019 Ford Explorer Discussion 16
P 2018 XLT Headlight Module Question Stock 2011 - 2019 Ford Explorer Discussion 3
S 2018 Explorer Platinum Driver's Seat Heater Module Fail (and Solution) Stock 2011 - 2019 Ford Explorer Discussion 2
S 2018 Explorer limited electrical issue Stock 2011 - 2019 Ford Explorer Discussion 3
Bobs2018Explorer How the OEM Oil Cooler works, on a 2018 with the 3.5 V6 Stock 2011 - 2019 Ford Explorer Discussion 3
M 2018 Ford Explorer Sport buzzing sound Stock 2011 - 2019 Ford Explorer Discussion 2
S 2018 Explorer - Front passenger side creaking sounds when accelerating from stop Stock 2011 - 2019 Ford Explorer Discussion 4
A 2018 Explorer Issues?? Stock 2011 - 2019 Ford Explorer Discussion 2
J 2018 V6 engine plug Stock 2011 - 2019 Ford Explorer Discussion 16
J 2018 Ford Explorer Lift Gate Stock 2011 - 2019 Ford Explorer Discussion 1
W Best rack/cargo cage for 2018 Explorer Stock 2011 - 2019 Ford Explorer Discussion 3
T Looking at 2017-2018 limited explorers Stock 2011 - 2019 Ford Explorer Discussion 3
L 2018 Ltd tailgate comes down Stock 2011 - 2019 Ford Explorer Discussion 10
C Various codes for 2018 Explorer Stock 2011 - 2019 Ford Explorer Discussion 0
M 2018 Explorer XLT 3.5L. Engine Whine/Whistle Noise Stock 2011 - 2019 Ford Explorer Discussion 38
A 2018 Explorer - slight rattle coming from engine compartment Stock 2011 - 2019 Ford Explorer Discussion 4
T 2016 vs 2018 Explorer purchase Stock 2011 - 2019 Ford Explorer Discussion 11
R 2018 explorer no throttle response Stock 2011 - 2019 Ford Explorer Discussion 6
J 2018 Ford Explorer XLT horn issue Stock 2011 - 2019 Ford Explorer Discussion 4
D Cigarette Smoke Removal from 'New to me' 2018 Stock 2011 - 2019 Ford Explorer Discussion 13
BubbaG 2018 Sport Windshield replacement Stock 2011 - 2019 Ford Explorer Discussion 1
R 2018 Ford Explorer Sport electrical issues Stock 2011 - 2019 Ford Explorer Discussion 2
S 2018 leaking oil Stock 2011 - 2019 Ford Explorer Discussion 3
E 2016, 2017, 2018 Explorer Sport Trim- Why? Stock 2011 - 2019 Ford Explorer Discussion 33
M 2018 Explorer Platinum Liftgate won't fully raise Stock 2011 - 2019 Ford Explorer Discussion 1
O Trailer connection 2018 Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
Michael W 2018 Explorer Platinum Rear Door Won't Open from Inside Stock 2011 - 2019 Ford Explorer Discussion 0
J Bought 2018 with 1200 miles - new question Stock 2011 - 2019 Ford Explorer Discussion 16
J 2018 with 1,200 miles dealer demo - is this a good deal? Stock 2011 - 2019 Ford Explorer Discussion 19
J 2018 Ford Explorer XLT outlets Stock 2011 - 2019 Ford Explorer Discussion 2
O 2018 XLT Climate Control Panel Bezel swap? Stock 2011 - 2019 Ford Explorer Discussion 0
W 2018 Ford Explorer Damaged Front Camera Stock 2011 - 2019 Ford Explorer Discussion 6
J 2018 Explorer Limited 3.5L oil leaks Stock 2011 - 2019 Ford Explorer Discussion 19
Bobs2018Explorer 2018 Explorer XLT - Front Tow Recovery Hook? Stock 2011 - 2019 Ford Explorer Discussion 20
J 2018 Ford Explorer RPM gauge not working Stock 2011 - 2019 Ford Explorer Discussion 8
Bobs2018Explorer Great experience installing aftermarket hitch on my 2018 XLT! Stock 2011 - 2019 Ford Explorer Discussion 27
N 2018 Platinum starts without key Stock 2011 - 2019 Ford Explorer Discussion 58
J 2018 Ford Explorer LED bulbs Stock 2011 - 2019 Ford Explorer Discussion 9
Bobs2018Explorer Where the heck is the trip odometer, in my new 2018 XLT? Stock 2011 - 2019 Ford Explorer Discussion 10
M New 2018 Limited (Tomorrow) Now Here Stock 2011 - 2019 Ford Explorer Discussion 15
J 2018 Ford Explorer XLT White Platinum Sport Appearance Package mods Stock 2011 - 2019 Ford Explorer Discussion 12
L 2018 fog lights Stock 2011 - 2019 Ford Explorer Discussion 3
N 2018 Escape issue Stock 2011 - 2019 Ford Explorer Discussion 25
Michael W 2018 Explorer Foot Activated Liftgate - Intermittent Stock 2011 - 2019 Ford Explorer Discussion 9
M Price check: 2018 Sport with 401A Stock 2011 - 2019 Ford Explorer Discussion 17
P Possible to add active parking assist to 2018 Explorer Sport? Stock 2011 - 2019 Ford Explorer Discussion 6
B Any issues with 2018-2019 Explorers ? Looking to purchase Stock 2011 - 2019 Ford Explorer Discussion 4
J Mounting Auxiliary Switches in 2018 Explorer Stock 2011 - 2019 Ford Explorer Discussion 0
E 2018 Platinum Extended Cargo Cover? Stock 2011 - 2019 Ford Explorer Discussion 3
N Will a 4'x5'x3" item fit in a 2017-2018 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 6
Similar threads
