2020 Explore ST and towing | Ford Explorer - Ford Ranger Forums - Serious Explorations
MichaelGl
Los Angeles
2014 Explorer Sport
Can any one please tell me if Explorer ST comes with the additional harness for trailer brake controller installation inside the cabin?
SteveAZ
Mesa, Arizona
2021 Lincoln Corsair
Don't think so. I recall seeing a video showing the two connectors but the brake harness was an option
MichaelGl
Los Angeles
2014 Explorer Sport
What connectors are you referring to?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Typically there is a port under the dash that the harness plugs into. You would have to buy the harness to connect from the port to the brake controller.
I believe the 2 wires mentioned above are referring to the 4 and 7 pin.
5th gen was behind the pa el under the dash.
2016 Explorer Brake Controller connection under dash
MichaelGl
Los Angeles
2014 Explorer Sport
So the ST does have a port under the dashboard to plug the harness in?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Well the ST has the tow package so it will have a port or plug under it.
