2020 Off-Road Experiences
Jons2020XT
Santa Fe
2019 Subaru
I am interested in experiences taking any model of the 2020 off road. I hope/assume that it is at least as good as the Outback even though it has about 1/2 inch less ground clearance.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I'm sure the Explorer has a longer wheelbase which can negatively affect off-road use under certain conditions.
Jons2020XT
Santa Fe
2019 Subaru
One quick follow up to this. when I look at the specs is says 7.9 to 8.3 inches for ground clearance. Is this unloaded vs. Loaded?
peterk9
Staff member
Moderator
Callsign
VE3
The specs sheet I have shows ground clearance for the Base, XLT, Limited as being 7.9" and Platinum 8.2". The ST is 8.3". I would think that those measurements would be 'unloaded'.
Jons2020XT
Santa Fe
2019 Subaru
Thanks very much. It is interesting that the one you would think is least trail-worthy has the most ground clearance - though not by much.
peterk9
Staff member
Moderator
Callsign
VE3
I believe in the 5th gen, the Sport was the lowest of the group.
cwescapexlt4x4
Explorin' the Desert SW
Litchfield Park, AZ area...
2016 Explorer LTD (FWD)
Yeah seems odd that the ST may have MORE clearance vs the others as it SHOULD be the lowest. Stock Outbacks have 8.7" of clearance.
Jons2020XT
Santa Fe
2019 Subaru
Yes, I will be trading an Outback for the Explorer and live in a place where there are some pretty rough roads, so I wanted to make sure the ST is at least as good as the Outback, allowing for the .4 inch difference which is not much. The lower profile tires on the ST are a bit of an issue, but should be reasonably strong given the fact they put off-road modes on the vehicle. I don't plan on trying the Rubicon with this :)
peterk9
Staff member
Moderator
Callsign
VE3
Don't forget that the standard tire on the ST is the 255/55R20.
Jons2020XT
Santa Fe
2019 Subaru
I plan on getting the Street Pack so that lowers the profile a bit. I just went back to the Ford site for the build I am working on and beyond 21" rims, it does not specify tire size. Pretty poor documentation. Do you know what the 21s are?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
275/45r21
Jons2020XT
Santa Fe
2019 Subaru
275/45r21
Thanks very much. I found a way to calculate the tire sidewall height which I think is the thing that matters. Here are the results:
The ST with the Street Pack:
275/45r21
10.82677*.45= 4.8720
Standard ST
255/55R20.
10.039370*.55 =5.5216
As a point of comparison, the Subaru Outback is:
225/60 R18
8.858 *.65 = 5.7577
Said differently the STs side wall is about 1" or about 20% which will matter, but there are no free lunches. I won't even look at Jeep Grand Cherokee sizes :)
Jons2020XT
Santa Fe
2019 Subaru
One additional question, though it is of broader interest than off-road or the ST. You can order the 2020 Explorer (I assume all models) with mud flaps.Has anyone done this? Do they make a difference?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
My original order had them but the one I bought did not. I would not get them personally. I've yet to see any type of tire spray on the sides of the vehicle and the fact that it is all plastic around the wheel wells... it will already prevent paint chipping.
peterk9
Staff member
Moderator
Callsign
VE3
Splash guards are an option that can be ordered for all trims. If ordered, they would be dealer installed. I had them on my 2011 but not on my 2017. They do help to a degree, mainly in Winter. I believe they had a minimal effect in keeping the rear window clean. Splash Guards
Jons2020XT
Santa Fe
2019 Subaru
My guess is that they were not helpful enough on the 2011 to be worth installing on the 2017. Correct?
peterk9
Staff member
Moderator
Callsign
VE3
That, and the fact that my salesman wasn't particularly in favour of them, pretty well sums it up. I lease my vehicles as well.
Jons2020XT
Santa Fe
2019 Subaru
Thanks, as you say, I could add them on at any time if I think they are important.
XploX
17 All-Terrain
The Explorer is far from an off-road vehicle. A low front facia, long wheel-base, and low approach/departure angles suggest keeping it on pavement, or the occasional dirt road.
peterk9
Staff member
Moderator
Callsign
VE3
No one has classified the 5th generation Explorer as an off-road vehicle but it does very well in light to moderate off-road as many articles/videos have shown. The front and rear overhangs have also been shortened on the 2020 model.
Rick 2020+ How to threads, TSBs, Recalls, etc. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
C 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 13
C 2020 Towing Mirrors Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
S Ford admits mistakes with 2020 Explorer launch, promises to fix problems Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
E 2020 Ford Explorer XLT Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 9
L Why I’m NOT running E85 in my 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 27
edwx 2nd row in the 2020 XLT.......now mostly Captain's Chairs? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 9
H 2020 Ford Explorer XLT transmission issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 13
C What is everyone paying now for a new 2020 ST? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 4
Y worry about new 2020 explorer limited (transmission) Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 26
J 2020 Explorer base looking for LED driving lights Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
S 2020 Explorer memory seat issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 20
R 2020 Limited Explorer with Serious Transmission Issues Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
J 2020 Ford Explorer XLT Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
1 2020 ST rear cargo light Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 4
M 2020 Explorer Hybrid CHARGING TIME Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 12
H 2020 Explorer assembly line video. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
J 2020 Ford Explorer Owners Event - Engineers Meeting Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
L You can now build a 2020 Explorer BASE with the Build & Price tool Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
K 2020 explorer door locks Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
M 2016 Wheels on 2020 Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
S Problem with audio on 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
C If you could buy a 2020 PIU or a 2020 ST - which and why? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 8
N Test drive and questions on a 2020 XLT Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
L No-Go for E-85 in 2020 ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
D 2020 Explorer ST Fuel Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
B Poor Gas Mileage in 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 14
J Selected to meet with Ford (2020 Explorer) Engineers - INPUT NEEDED Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 76
T Selected to meet with Ford (2020 Aviator) Engineers - INPUT NEEDED Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 33
T 2020 ford explorer less then 2000 miles tire compartment full of water Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
B 2020 Ford Explorer ST driver seat issue. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
M Overall impressions of the 2020 Explorer? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 49
D 2020 Explorer Fault Codes Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
T Black Accent Color on 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
J 2020 ST Oil Spec? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
Sharin Who is dissatisfied with the 2020 Ten-Speed Trans Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 118
B New member. 2020 Explorer ST air issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 8
J 2020 Explorer Battery drain Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
B 2020 Paint Issues Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 20
G 5-Star rating Euro NCAP for 2020 FORD Explorer PHEV Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
K 2020 Explorer Limited vs ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
B Buying a 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
M 2020 ST Starting Problems Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 11
O Going from a 2013 to a 2020 Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
K 2020 Explorer Transmission Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 24
T Failed transmission replaced with a reman unit - 2020 Limited with 2300 miles Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 13
TBill 2020 Platinum Headlights Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
fast_dave 4wd Layout of 4 Cylinder 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
TBill 2020 Platinum waiting for final delivery Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 12
R 6 weeks in many issues 2020 limited Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 12
Similar threads
