Thomas Thayil
T T Engineer
- May 14, 2017
- east meadow
- 2020 Explorer LTD
Anyone knows if they have an update coming up for that
For these item, yeah the system takes maybe a 45s - 1 minute to fully boot everything, especially if you have Nav. The full boot isn't hidden by the splash screen. In that first ~minute, you'll probably notice delayed responses since it's under load. It's most noticeable if you jump in, start and go really quickly as the boot isn't being "hidden" then. If you're on the initial software (19101), you can hit the dealer for the latest (19200). There's another one coming that, I believe, will be a user update.
Sorry, this is an old thread and you may not be tracking it anymore, but I thought I'd give it a shot.
I'm on 19101. I spoke to my local dealer (both the service manager as well as the service advisor I have previously used) and neither understand anything about dealer updates for Sync. They both believe that the only updates for Sync are those done by the user. Is there anything I can do to explain to them what to do in order to move me from 19101 to 19247 (or whatever the newest build is)? Or am I best off just to wait until Ford releases an update the user can install themselves?
Oy. They should have the software to do it. I can't believe they have never updated a module in some warranty service, etc. over the last many years. Unless they're one to just part swap. If you're not having too many problems with 19101 at the moment, it might be easier to wait for the official update. Hopefully not too far off. Several sites have the 19274 app and voice packs available to download if you wanted to DIY, though your mileage will vary on the accuracy of their instructions on what to update.
Thanks for the reply! I'm not experiencing any issues with 19101, other than it can be fairly laggy at times (sometimes it's responsive to touch, but sometimes I touch a selection on the screen and it takes several seconds to register). I'm not sure if the newer builders are more responsive/less laggy.
If anyone else is looking to upgrade to sync build 19247, I followed these instructions and they worked for me.
On a USB drive, create a folder called "SyncMyRide".
In that folder, paste in these files:
Go out of that folder (up a level), and create a notepad file called "autoinstall.lst" next to the "SyncMyRide" folder (note: the file extension needs to be .lst not .txt).
- 3.4 app 5U5T-14G381-CJ
- 3.4 compatible voice 5U5T-14G391-CK
In that notepad, file paste in this text:
[SYNCGen3.0_ALL]
Item1 = 5U5T-14G391-CK_1571088381000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G391-CK_1571088381000.TAR.GZ
Item2 = 5U5T-14G381-CJ_1571083986000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G381-CJ_1571083986000.TAR.GZ
Options = AutoInstall
Then, I just plug it into the Explorer's USB port and it does everything automatically.
Does anyone has links to the latest files?There are newer files available. SYNC 3.4 20021 and NA Maps 1.19.
Check this post as to where you can get it. Sync V3.0 to V3.4 UpgradeDoes anyone has links to the latest files?
I spot checked. They still have invalid file package pairings.
