2021 King Ranch - Sirius Radio randomly cuts off | Ford Explorer - Ford Ranger Forums - Serious Explorations
Blisster
Prosser
2021, Explorer King Ranch
We have a 2021 Explorer King Ranch. We have a sirius subscription and use it regularly, and usually with no problems. We do have occasional loss of signal due to trees or mountains in certain areas (we live in Washington state so pretty far north) and this is normal. BUT we have random problems where the sirius radio cannot be selected and will not play. This typically happens when we shutoff the car for a few minutes like at a gas station, then restart the car and Sirius will have zero output, and we cannot select other sirius stations. We can select any other audio source and they all work fine, but not sirius. The only way to get it back is to shut off the car for about 20-30 minutes (we have not actually timed it, but a short time like 2-3 minutes will not reset the radio). Has anyone else had any similar problem with sirius? We have had the car into the Ford dealer service but they cannot repeat the problem. They have done a "factory reset" on the electronics system but didn't fix it. We also have done the "reset" with Sirius but problems continue.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Dale5403
Mondovi, WI
2020 Explorer ST
Do you have the newest software version 21194? If not try updating it and see if that helps.
Blisster
Prosser
Not sure... I guess I need to learn how to check the version and do an update. I'm not familiar with how to do that yet. I would assume that the Dealer service techs have already done that, but I can't say for sure.
1sicbronconut
Rapid City
1968 Ford Bronco
There's a TSB that covers that concern, a dealership should be able to help you by doing an update. One of the first listed concerns is Sirus not functioning after a key cycle the TSB# is 21-2411
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Ensuring that you have the latest update installed should be part of the dealer prep procedure. That said, it is always best to check that it is.
I believe the update mentioned by Dale solved the issue.
Dale5403
Mondovi, WI
2020 Explorer ST
Depending on when his vehicle was delivered it could have had the latest software installed. 21194 wasn't released until Aug 27, 2021
Blisster
Prosser
I did NOT have the 22194 installed. So I downloaded and installed the update. So far we have had no more issues with Sirius - seems to have resolved the random problems, but time will tell. I am a bit surprised that the Ford Service did not do that update when I brought it in last December. Thanks to all who provided the answers... Much appreciated!
Dale5403
Mondovi, WI
2020 Explorer ST
Glad to hear that version 21194 has helped. It is amazing how many issues from the 2 prior versions it fixed. Thanks for reporting back.
