22's on an Explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
22's on an Explorer
I have a '94 Explorer and was wondering if it is possible to fit 22" rims on it. I found a set with Pirelli Scorpion 295/30/22 tires for a good price. Does anyone have any idea how close that will come to the wheel well? Thanks.
-Mike
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
ok89
College Station, TX (school) / Houston, TX (Home)
02 Wrangler X
thats about 29"x11.6" So height wise its fine but im not sure about the width There could be minor rubbing
John Doe
Dayton, OH
'94 EB
The rims are 22x9.5.
What is the bolt pattern on the Explorers?
-Mike
ok89
02 Wrangler X
5 on 4.5
John Doe
Dayton, OH
'94 EB
They are 22x9.5 with a 5x120mm bolt pattern which is 5x3/4. Will that fit an Explorer?
-Mike
mikeymed8
MA
'94 XLT
You will definetely have some rubbing with those wheels. I'm running 20's on my X and they rub when I cut me wheel all the way, either way. I'm running a 265/50 tire on them.
Mike
Hartman
Indianapolis, IN
It's all irrelavent because that bolt pattern will not work on an Explorer. Unless you run some rubber band tires, rubbing is almost a given. Those rims are very wide as well. I would go with 20's, 22's on an Explorer is going to be nothing but trouble.
