289 np435
Dumple
Ohio
1992 Explorer
OK i know that a 302 and 5 speed is going to be a better option but im getting my hands on a 289 for $free.99 and i can find an np435 for cheap too. My question is does anyone currently run a small block in the 1st gen b2/ranger? Im sure i could figure out getting the 289 in there just fine but im worried about the np435. Ive currently got a 4.0 and a4ld and both arent feeling quiet right. tranny wont shift right and i miss having that skinny pedal. So i know ill need to fab up a cross member, the tranny and probably an np205, the pedal assembly, the slave, the master, the linkage for the clutch and t case, engine mounts(dufftuff) and a bigger wallet. Is there anything that im forgetting? The b2 is fairly clean on the inside and id like to not have a huge hole in the floor pan if i can avoid it. Will the shifter line up? will i need new drive shafts? Is there a major reason not to do this swap? any help is appriciated. And before anyone asks why i would want to do this, because im a free man and i can.
roscoe 0202
salt lake city utah
1999 explorer sport
look for a m50r2 trans it will bolt up to a 6 bolt clutch housing 289 the 5 bolt clutch housing would fit tunnel in bII better but the trans would br problematic since the housing is early narrow pattern.
roscoe
Dumple
Ohio
1992 Explorer
Ok the 289 is a 6 bolt so I can use either one. I know the m5od-r2 is a better option but I'm specifically asking about the new process right now.
