297X joints & pre78 D44's? | Ford Explorer - Ford Ranger Forums - Serious Explorations
MFergy
Bozeman,MT
94 XLT
Ok, so a question for all those running cut down 78-79 Bronco D44's, if you cut according to all the numbers found on this site, and used the inner axles from 71-77 Bronco's.. Don't the 71-77 D44's use smaller u joints not the 297x's that the 78-79 D44's use. How do the inner and outer axle halfs meet up?
tdavis
Linux Guru, Jack of All Trades
Staff member
Admin
Pinole, CA
2001 F250/XLT Superduty
Callsign
KG6MAX
You simply order the heavy duty parts, which get you the 297x joints.
MFergy
Bozeman,MT
94 XLT
Thanx Thomas, are these parts expensive and where might I find them? Do you replace the whole inner and outer axles shafts on both sides?
tdavis
Staff member
Admin
Pinole, CA
Callsign
KG6MAX
You should be able to just order the inner shafts, and reuse the outers.
Best to call the axle shaft people, and talk to them about it, to verify everything.
