2nd gen fixed manual replacement antenna | Ford Explorer Forums - Serious Explorations
waren
2000 Explorer EB
Hey guys, I purchased a 1999 limited with non functioning power antenna. I planned to take the fixed antenna and base off my 2000 but the cap nut was seized and I ended up busting it trying to remove (and still can’t get it out). Seems like ford has discontinued the lower mast ... and to top it off I pulled the antenna cable and it flopped into the door hinge and cut ... so frustrated.
I can’t get the cap nut off ... but I can lift it enough to see that I cracked the base. I think I can also see that I sheered a key off the lower antenna mast although the lower may still be usable. I can’t tell for sure yet, I need to pull the whole fender off remove the steel bracket so I can pull it up through the hole.
ok questions.
to convert from power to fixed antenna what exactly do I need?
1) there are two different bases one for power (F5TZ-18922-A) one for fixed ( F5TZ-18A984-A). Can I use the power base to install my fixed lower mast?
2) Are there any other bases that will work? Like from a ranger or something?
3) does anyone have a part number for the explorer fixed lower mast (I have the upper “whip”)
many help greatly appreciated!
