I would think this information already exists somewhere else, but I searched forever and couldn't find it. Anyway, if you're trying to wire up some lights that turn on and off with the puddle lights the wire you're looking for is black with a light blue stripe. One of the locations where you can access this wire is behind the driver's side fuse panel inside the car. You take out the 3 screws that hold the fuse panel down and pull it out (it won't come out that far because of the wiring to it). The group of wires (the smaller of the two groups that runs behind the dash) that contains the puddle light wire can be pulled out far enough to work with. Now, you'll notice that there are actually 2 black/light blue wires. One is for the interior lights (excluding the puddle lights) and the other one (the one that you want) is for the interior lights again AND the puddle lights. I figured out which one was which simply by cutting one and seeing if the puddle lights shut off (I cut the wrong one first).
In my specific case, I was needing to splice into this wire to power the halo rings on the auxiliary lights I'm adding.
I hope someone finds this useful.
