Well thank you, I never actually planned on doing the 4wd swap, I had always planned on converting it to a 5 speed then getting 3 in spindles, and locking the rear, until I could eventually in 5 or so years do a SAS. Anyways I found the spindles for like 400 bucks and figured for near that amount of money I could just have 4wd. Since your keeping your auto trans it will be a much simpler swap, it really is not hard to do as everyone says, I had never even pulled a trans before. What you should do is find local junkyards near you that are self serve, heres one,
http://www.upullandpay.com/albuquerque/part-prices.
I got my transmission and transfercase at the junkyard 125 for the trans and 60 for the transfer case. I also got both driveshafts there 15 a piece. Then I got my whole front end from a ranger off craigslist for 150. So I probably spent 400 bucks including diff oil, trans fluid, and gasket maker.
The best thing about the pull a part places is since your pulling it yourself, you will know exactly how to put it back together in you truck. Looking at that websites prices, they seem to be a bit cheaper than mine, you should definetley be fine under 400 without taxes, figure 500 to be safe.
heres a quick list of all you should need
1. 4wd trans, not sure what years the autos differed, I would look into that.
2. Transfer case, personally I would get the 1354 out of a 1st gen so you have true 2wd, unless you want the weird ass auto 4wd haha.
3. front and rear driveshafts, from a 4 door if you have a 4 door. If you do get a 1354 from a 1st gen, then you will need a front shaft from a 1st gen.
4. front diff with same ratio as your rear.
5. front half shafts, CV's. the lower the mileage the better.
6. 4WD knuckles.
7. 4WD Rotors.
That should be it, but I am tired as hell so I might have missed something. Anyways if you really are attached to the truck like I am, then go for it, Plus the feeling of what you have accomplished the first time you put it in 4 low is quite unbeleivable, its also nice being able to stop in sand, and then be able to leave haha.
Chase
