88TurboCoupeA4LD
- April 29, 2008
- Lockport, Illinois
- 1998 Eddie Bauer AWD 5.0
OK... 1st Off... I Just Want To Say HELLO To EVERYONE Out There & Thank You For ALL Of The Great & Useful Information In This Forum...
I Own a 1998 Eddie Bauer Explorer 5.0 V-8 Full Time 4WD, But I Do NOT Have ANY Issues With This Vehicle Since I Bought It Brand New...
I'm Currently Tinkering W/ A 92' Ranger 2WD That I've Swapped Over A 1988 Turbo Coupe Drive Train In To (2.3 OHC I-4 Turbo W/ A4LD Auto) & YES... You've Guessed It - I'm Having TRANSMISSION TROUBLES !!!
The Problem Is That Almost EVERYONE That I Inquire About This Setup Just Tells Me To Switch Over To A 5 Speed Manual Trans - But That's NOT What I Want!!!
***QUESTION #1***
Is There A TURBO SPECIFIC Modulator That Is SUPPOSED To Be Used With An A4LD With A TURBO ENGINE? (I've Seen Them Listed At Different Trans Parts Websites As DISCONTINUED Items...)
***QUESTION #2***
Is There A TURBO SPECIFIC Torque Converter To Be Used With My Setup??? Are ANY Of The A4LD Torque Converters BETTER / WORSE Than Another (MOST SEEM TO BE INTERCHANGEABLE From The 2.3 All The Way To The 4.0)-(PLEASE - CORRECT Me If I'm Wrong) I've Seen Replacement Torque Converters Listed For The 2.3 Through 3.0, One Listed Just For The 2.3 N/A, One Listed For The 4.0, And Then They List A TQ For The Merkur 2.3 & 2.9's
But ALL Of The Measurement Specs Are The SAME For All Of These & They All Have Different Part #'s... My Question Is : WHICH TORQUE CONVERTER Would BEST Suit My 2WD 2.3 TURBO Ranger W/ 88' Turbocoupe Drive Train?
I've Been Through 2 Junkyard Transmissions That I've Upgraded The Valve Bodies, Governor, Bands, & Servos On... The 1st Trans I Ran Was Stock (I Believe, But NOT Sure) From The Donor Turbocoupe. The Next 2 Transmissions That I Blew Through Were 1 From a 93' Mustang 4 Cyl., & 1 From a 94' Explorer 4.0 That I Swapped Over The Bell & Tail Shafts On... NONE Of These Transmissions HELD UP To The TURBO 4 Cyl. (MILD Upgrades To The Engine / Turbo / IC - Running About 265hp)
So Now... I'm Doing It All OVER AGAIN... I've Got a Couple Of GOOD CORE A4LD Trannies To Start With, But I've NEVER Been Able To Find Anything Out About The Modulator & Torque Converter That Would BEST Benefit My Setup. I'm Going To COMPLETELY REBUILD The A4LD With As Many Of The Updates & Sonnax Parts That I Can Get My Hands On... But I Don't Want To Spend An ARM & LEG On This
- Which Torque Converter & Modulator Should I Run When It's All Said & Done? Are There Any GOOD Rebuilt Torque Converters Or BETTER Stock Ones That Ford Produced That I Should Look Into? ANY INPUT ON THIS WOULD BE GREATLY APPRECIATED... THANK YOU... - Derek
***QUESTION #1***
***QUESTION #2***
