CallMeSyd
- March 31, 2021
- Hattiesburg, Mississippi
- 2004 Explorer NBX 4.6 4x4
I have a 2004 NBX 4x4 with open 3.55 diffs and AdvanceTrac. I also have a 2002 Limited 4x4 with the full tow package including 3.73s with LS in the rear. Is it possible to swap the differentials between them? I read somewhere that the AdvanceTrac equipped models have a sensor and tone ring in the differential. Is this true? If so, will it cause issues if I put the diff without it into the AdvTrac? Or is there a way to swap the tone ring and sensor over? Also, will the wheel speed difference from the 3.73s cause issues with the ABS, PCM, or traction control? If so, can it be programmed to accept the 3.73s? Will the LSD fight against the traction control? Any issues with the 3.55s going into the 02? A lot of questions here I know but any help would be greatly appreciated.
