bmxking5
- May 2, 2004
- Monroe, GA
- '93 Sport & '96 XLT
Ok, I've been planning on swapping in a 302 into my truck soon after the axle swap is done. I've seen how expensive it is for the Advance Adapters parts to use with my truck, and wanted to find a way around spending 500+ dollars on adapters, so I figured I'd see if a 302 could be used (with the trans and t-case) from a ~92 F150. I know that there could possibly be a problem with clearance, but other than that, it seems like it would work as good or better than any other 302 setup. I believe that AudioDude (or something like that) was doing a similar swap in his Explorer with an F150 setup, but he never really finished saying how the swap was going.
After seeing my friends '92 F150, and seeing how nice of a setup he had (302, ZF5 manual 5 speed, and manual BW1356) I feel that this year range/model would be a perfect candidate for a donor truck for the swap.
I believe the F150 would be OBD I, so if that's true, I obviously wouldn't need to convert from OBD I to II, like I would with a newer Mustang or Explorer motor. Also, I'd run the motor mostly stock for a while, so it'd have a cam that would suit my truck more than the mustang cam would. The best part about using the F150 setup is that I could use the ZF5 5 speed manual transmission (I have a manual now, and want to stick with a manual) instead of the T5 transmission. I don't like the T5 because it has an even higher first gear than my M5OD-R1 (M5OD-R1 = 3.4 I think). The ZF5 has a 5._ (or lower) first gear IIRC so it's nice and low! Also, I wouldn't have to worry about buying the AA adapter to allow a t-case to be bolted up to the transmission (like I would with a T5), b/c I could simply use the Borg Warner 1356 that comes on the back of the 4x4 F150's of that year range. When I feel that I am knowledgeable enough, and more importantly my wallet
is ready for the motor swap, I plan on buying a donor truck and pulling the motor, transmission, transfer case, wiring, etc and putting it all in my truck.
So I was wondering if some of you guys see anything wrong with this. Are there any more problems I'd run into with this setup over another 302? I realize that I might have some clearance problems with the gas tank,etc but that shouldn't be too big of a problem. Also, I know I'll have to do some things with the A/C, etc so that I can complete the swap without a BL. So far it seems like a really nice, strong setup that would be great in my truck. Any opinions (good or bad) are appreciated.
EDIT: Oh and by the way, I will have some more experience with engine swaps toward Christmas time. In my auto class, my teacher has already told me that he thinks I'm one of the smarter kids (I feel so special
) in the class and he wants me to be one of about 2-3 kids to complete the 383 swap into the '73 Camaro. It still needs to be wired up, etc, and I know it will be much different than a motor swap in an Explorer, but hey...it's still experience with an engine swap.
