31's or 32's or 33's? | Ford Explorer Forums - Serious Explorations
hornz2000
Athens, GA
1998 Sport
Sup guys. I am new to all this modification stuff so I have some questions for you. I want my car to look like this...
What size tires do you think those are. Do you think he has a lift or what. I want my car to look like that right now it is all stock. What mods do I have to do to get it to look like that. My only thing is that I want the widest tires possible.
Hey, what's up man. It look to me like at least 32s on 15X7" wheels with about 3 inches of lift. Either body lift or or torsion twist and shackles or some sort of combination. You can buy new wheels and get wider tires if you want as long as you get wider wheels. Good luck.
Judging by the amount of the frame I can see under the body, it looks like it has a 2 or 3" body lift. The tires are at least 32's, but more likely 33's. (not that you can tell in a picture) To clear those, there'd have to be some sort of suspension lift also. I'm assuming the torsion twist up front with longer shackles or add-a-leafs in the back.
If you want your truck looking like that, do a 3" body lift, torsion twist, and longer shackles/add-a-leafs. Then put some 33's on it. 33x10.50's will fit on stock rims if you don't want to buy new ones.
