33” tires
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
Got some gonna get em installed soon was jw what kinda mpg others may be getting w similar setup? Not gonna stop me just be nice to know ahead of time lol
jw1000
California
2005 Ford Explorer XLT V6
It depends on your motor and if your explorer came with 3.73 gears or not. Also, other factors can effect it over time. Generally speaking, you should get a bit better highway mileage, but worse city mileage. Once bigger tires get moving, they cover more ground, but it takes more gas to get them going. Also, if you don't have at least 3.73s it might be a struggle to get up to speed
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
Thanks, stock ass 4.0 , 3.55 gears and it’s already not that quick so you’d be correct. Already have 2, the other two are on the way getting pretty much whole front suspension redone w moog when I get them mounted will be before Christmas. Mainly want them for the extra ride height as I’m 6’1 and still stoop down to get in. Prob talking what 12-13 mph in the city?
jw1000
California
It is hard to know until you try it. Even left stock, any car will get different mileage over time. You shouldn't get worse than 12 as long as you aren't super hard on the gas and just deal with it being slower. I get 14 combined mpg on 32 inch all terrains with a 4.0, 3.73s, and 140k miles.
M 22” rims. Question is the tires Modified 2002 - 2005 Explorers 6
M Quick lifts and tires Modified 2002 - 2005 Explorers 8
W Tires Modified 2002 - 2005 Explorers 3
J Lift/Leveling for bigger tires? Modified 2002 - 2005 Explorers 13
2 35" tires Modified 2002 - 2005 Explorers 18
T Off Road Tires and Wheels for 2005 Explorer XLT Modified 2002 - 2005 Explorers 5
C New Wheels, Tires, and Brakes for my 05 Limited. Modified 2002 - 2005 Explorers 4
X Biggest size tires w/ 3" lift? Modified 2002 - 2005 Explorers 2
E Got new tires ahead of schedule Modified 2002 - 2005 Explorers 1
X 2.75 inch front 2.25 in. Rear 245/65/17 Firestone Destination AT tires Modified 2002 - 2005 Explorers 6
M tires, lift, exhaust ect Modified 2002 - 2005 Explorers 4
B lifted explorer how big of tires can i go? Modified 2002 - 2005 Explorers 3
J Will bigger tires affect my speedometer? Modified 2002 - 2005 Explorers 3
3 Tires or rims? Modified 2002 - 2005 Explorers 6
4 Tires on 15 inch rims Modified 2002 - 2005 Explorers 9
0 Bigger tires. 3" lift in the front Modified 2002 - 2005 Explorers 1
A Best tires for 2003 Ford Explorer Modified 2002 - 2005 Explorers 4
T Will size 285 tires fit using only coil spacers to lift? Modified 2002 - 2005 Explorers 15
R New Tires coming!! :) Modified 2002 - 2005 Explorers 7
D New tires for 05 Expl XLT 4WD 4LV6 help!!! Modified 2002 - 2005 Explorers 3
C Dakota Definity AT tires would not fit. Modified 2002 - 2005 Explorers 10
K Cragar soft 8s with 32" tires or roof basket Modified 2002 - 2005 Explorers 2
R 2nd gen snow tires Modified 2002 - 2005 Explorers 4
D 04 Explorer XLS 4WD w/ 265/65r18 30" wrong diameter tires what to do? Modified 2002 - 2005 Explorers 0
J Need help with tires/rims with 0 or -12 offset Modified 2002 - 2005 Explorers 3
H Largest Tires Without Lift? Modified 2002 - 2005 Explorers 28
G Lift and tires! Modified 2002 - 2005 Explorers 5
A Please Help! Question About Tires. Modified 2002 - 2005 Explorers 2
G Tires and wheels! Modified 2002 - 2005 Explorers 8
B 18x8 wheels with 255/55R18 Tires. Problems with auto 4x4? Modified 2002 - 2005 Explorers 2
C 114t tires? Modified 2002 - 2005 Explorers 6
A Retread tires Modified 2002 - 2005 Explorers 9
B Effects of bigger tires on transmission Modified 2002 - 2005 Explorers 7
K 2004 Explorer NBX Bigger Tires Modified 2002 - 2005 Explorers 15
J Inconsistent vibration after new tires Modified 2002 - 2005 Explorers 14
E Finally got new wheels and tires. Modified 2002 - 2005 Explorers 28
U Anyone have 2.25"/1.75" spacers and stock size tires? Modified 2002 - 2005 Explorers 14
A New Tires and Updated Pictures Modified 2002 - 2005 Explorers 9
4 New tires+rims... maybe. Modified 2002 - 2005 Explorers 4
R Lift is done... Tires are on!!! Modified 2002 - 2005 Explorers 25
G 3inch body lift+Rancho Quicklift= what size tires? Modified 2002 - 2005 Explorers 1
C BTF Upper Control Arm/ 33" tires Modified 2002 - 2005 Explorers 39
4 Body lift and tires Modified 2002 - 2005 Explorers 6
M What size Tires should I get? Modified 2002 - 2005 Explorers 3
4 ok body lift good now tires 265/75/16 on stock wheels Modified 2002 - 2005 Explorers 1
4 got body lift, tires? Modified 2002 - 2005 Explorers 11
E Need opinions on wheels and tires Modified 2002 - 2005 Explorers 25
R Shopping for new tires. Modified 2002 - 2005 Explorers 13
HiImBrian Shopping tires..... Modified 2002 - 2005 Explorers 26
J Better off with stock sized tires? Modified 2002 - 2005 Explorers 5
Similar threads
