Should be no problem at all. The '01+ 2dr Sports have larger wheel well openings than earlier models (2dr and 4dr), so fitting larger tires is a little easier. I had 32s with stock suspension and no rubbing except on the anti-sway bar at full turn.
Now I'm running 33 x 11.5s with just a TT and F150 rear leaves. Total of about 1.5" of lift. Stock shackles, stock 16" wheels, no body lift, no AAL, no trimming, no rubbing.
If I had wider wheels and/or tires, there would be be rubbing when turning. The extra 3" of body lift would easily take care of that without trimming any body parts. Would probably look better with it higher too. I plan on a BL and wider wheels someday when the budget allows.
