- May 13, 2009
- Los Angeles, CA
- 1997 Monsterneer
- Callsign
- KI6MCO
My 5.0 has seen better days (212K miles) so I am looking to build a new motor for it. Since I do ALLOT of towing miles with it, I am considering building a 347 stroker for it. I believe that what I am after is an “off-idle” torque motor. All in by 5000 RPM is fine. It needs to be smogable in California though. I’m thinking of using a block from a 1996 Explorer I have from a motor that developed rod knock. Have the block gone thru and machined. Throw in a 347 kit and some aftermarket heads, a nice cam and go. I have Torque Monster headers on it. No muffler, but all 4 cats and ran all the way out to behind the rear tires seem to quiet it down. The lack of muffler has not been an issue with smog. They say the muffler is not part of the smog equipment so its not a problem. What else do I need to change/know? I would defiantly prefer to end up with something that will still pass the standard California smog testing. Pretty sure I will need to talk to Damper Dudes about a dapener for the 347. Will I require different injectors? MAF? Throttle body? ECM programming? Other stuff?
Things to consider because of the 347 build:
Harmonic Balancer:
Because 347 kits are primarily designed with the Mustang crowd in mind, they are all typically 28oz balance type. Our Explorer specific harmonic balancer is 50oz balance.
- Rework a 28oz harmonic balancer to work with the trigger for the Explorer. Probably not an option for this since I have not ran across anyone that has done this and retained the Explorer belt/pump system. I did see mention of a couple years of Cobra harmonic balancer that are more similar to the Explorer, but are balanced to 28oz.
- Re-balance the crank to work with the 50oz balance stuff. This option is interesting. From what I see some cranks do not have enough meat on them for this though. Will need to work with some local balance shops and see what they think.
- Have a custom harmonic balancer made that will work with the Explorer belt system and balanced for the 28oz crank.
Dampener sources:
ron at damper dudes Welcome to Damperdudes.net
Thier dampener specifically made to work with the Explorer front dress and ingnition trigger wheel, reballanced to 28oz:
PN: FO3024EX28OZ
(Just under $200 as of 8/2021)
Flexplate:
If I stick with the 28oz balance on the 347 crank, I will need a flexplate balanced to 28oz and the correct tooth count for my starter.
Injectors:
The increased displacement may end up running the stock injectors in excess of 80% duty cycle. If that happens I may have to change to a larger injector set. Since my build intent is not a high RPM build I might get away without this though.
MAF:
Larger injectors means something will need to happen here. Re-calibration or a matching MAF to the new injectors.
Fuel pump:
With larger injectors comes the possibility that I may have to supply more fuel, but not likely given the power curve I am looking to get.
Cam/vacuum:
I am looking to build a monster torque motor. I am hoping that I can achieve that with a cam that will still provide good vacuum at idle.
ECM tune:
In the end I am hoping that the motor can run acceptably without a tune. I believe it is possible to select matching injectors/MAF that would allow this. Of course to get optimal performance I will need a tune. Will need to discuss what strategies would work best with the tuner people.
Tuners:
don lasota a call or email at LaSota Racing Technologies
Here are some other 347 build related threads I am referencing:
347 question
5.0 347 swap
Stroking an Explorer 5.0L engine?
My rig description: Monsterneer
Motor builds that are inspiration:
"base" 5.0 engine: Ford 302 Base Engine 300HP Crate Engine
347's:
Fordstrokers
SMALL BLOCK FORD
FORD BluePrint Engines BP3474CT BluePrint Engines Ford 347 C.I.D. 415 HP Base Stroker Long Block Crate Engines | Summit Racing
CNC Small Block Ford 347 Stroker Street Engine, 390+ HP
BluePrint Engines 347CI Stroker Crate Engine | Small Block Ford Style | Longblock | Aluminum Heads | Roller Cam
347 Ford Small Block Stroker Crate Engine: F347-HR-C1
347 Stroker "Balboa"
Ford 347 Stroker Base Engine 410HP with Fox Body Oil Pan
Type of use:
Towing (85% of miles):
I do ALLOT of heavy towing with this rig. I tow a 8.5x16x7 enclosed aluminum trailer with it on long hauls anywhere from 150 miles one way to 1000 miles one way. The total load of the trailer is about 4500 pounds (trailer weight, SXS weight, camping gear, ice chest…). My rig weighs in at 5000 pounds when loaded for travel.
Wheeling (10% of miles):
I do off-road this rig when I am not towing with it. Always driven to the trails, never trailered.
Typical RPM’s:
70MPH in OD ~2300 (rarely in OD while towing. The 5.0 won’t pull it!)
70MPH in D ~2900
My power objective:
MONSTER TORQUE, high 300's from idle thru red line. 400 would be great.
HP..... whatever HP results from the torque curve I am looking for will be just fine. I'm not building this for HP, I'm building for torque.
Red line: all in by 5500 RMP or less!
Torque/HP curve desired.
Harmonic Balancer:
Dampener sources:
PN: FO3024EX28OZ
Flexplate:
Injectors:
MAF:
Fuel pump:
Cam/vacuum:
ECM tune:
Tuners:
347 question
5.0 347 swap
347's:
Fordstrokers
SMALL BLOCK FORD
Type of use:
Typical RPM’s:
70MPH in D ~2900
My power objective:
