38.5s, 4-Linked, Coilovered, and Full Width | Ford Explorer - Ford Ranger Forums - Serious Explorations
Well I'm going to go ahead and post this. I might be buying tommarrow my D44/9" combo out of a 78/79 Bronco(Don't remember which). I will then start collecting parts so I may get ready to do my buildup. Here are my plans:
- D44 front w/ Detroit, 5.13s, Superwinch Hubs, New Shafts & Joints, Hydrosteer, Crossover Steering
- 9" Rear w/ Detroit, 5.14s, Discs, 31 Spline Shafts
- Custom Built 4-Links Front/Rear using some big ole tube and some nice heims
- Coilovers(Not sure on size, spring rates or anything like that)
- 38.5x14.5x15 Swamper SX mounted on Trailready or Rock Stomper Beadlocks
- Front Winch Bumper, Rear Tire Carrier, and Possibly a Roof Rack
- 4.0 is getting some motor work(BBK TB, TB Spacer, Intake, Exhaust, Cam(Possibility), and a Chip
- Tranny will be getting a shift kit and maybe a few other things
- 6" Bulge Front Fiberglass and 4" Cowl Hood(Functional)
That will be all for this part of the buildup. The truck is currently my SPL comp vehicle and will stay that way. I originally just wanted to lift the truck and what not but I miss my rock crawlin days(XJ on 35s & a CJ on 39.5s) so I figured hey why the hell not. I should be ok leaving my system in the truck because I shall be bolting it down and what not. I will also need to probably have a cage built for this truck. This build will probably take awhile(Fact that I'm 18 and still in HS) but I hope to have it on 38.5s and Coilovers by the time the Badlands Run rolls around. We shall see.
034x4
B'ham
2003 Ranger Edge
Don't get a roof rack if you like a low cog, even though on a lifted explorer thats hard to do already.
FROADER
Staff member
Moderator
Huntington Beach, CA
1991 Eddie
Damn, from the title I thought it was already done and ready to see some pics. Sounds like a good plan. I'll be waiting for pics of this bad chicken.
I just took my roof rack off. I would only put one on if you know you're going to use it, otherwise there is no point.
Good luck! :thumbsup:
supergildo
fort collins, co
02 ranger
roof rack isnt gonna make much of a difference jey... probably BARELY noticeable.
sounds good. I have those axles and im buildin em up. good luck!
IndyExploder
Greenwood, IN
'92 XLT
see the only reason I went for the roof rack was because my sub box takes up the whole back end and when I want to carry some spares and I had 4 people with me I don't have a place to put them. If its just me a another person or what not they will be inside.
034x4
B'ham
2003 Ranger Edge
If he starts putting spare parts/tools or maybe even a spare tire, it will be very noticeable, which isn't that the point of a roof rack?
IndyExploder
Greenwood, IN
'92 XLT
Well it looks like the truck has gone a different direction. I have an 88 Bronco Frame to work with. HRMMMMMM........
The plan now is this.
Bronco Graveyard 10" Solid Axle Conversion(Going to get around 15" total lift)
D60 Front w/ 4.88s, High Steer, Hydro, and a Detroit
D70 or 14Bolt Rear w/ 4.88s, Discs, Detroit
46" Claws
And after all that is completed on the frame, the explorer body is going on the bronco frame.
mitch
high point, NC (home) charlotte, NC (school)
94 limited
that sounds like a plan to me. cant wait till everything gets started so i can see some pics :D
