fofopirata
- February 3, 2011
- Tijuana Mexico
- Explorer 2002 XLS FX4
new tail lights guards
Ashamed that you didn't try to climb a higher part of it? YESlol
You must have an lsd? Last time I tried doing that on a snowbank I couldn't get the back wheel off the ground...pffffft lol
Still think those rims look 1000 times better than your original stockers
Its got a "Brake Locking Differential" as part of the AdvanceTrac system. You'll find that 05's can out do 02-04's big time because of the AdvanceTrac.
Don't know much about the Explorer's AdvanceTrac system. What is the difference between that and the regular 4 wheel drive system??
So far I haven't had a problem with my Explorer. Last winter I was driving through snow up past the running boards. My '03 came with LSD's.![]()
You're on of the lucky ones with LS diffs. haha
Well there is no difference in the 4wd system if you have advance trac or if you don't. The main difference is, is how the abs and braking system works. Advance Trac monitors wheel speed and all this other stuff to prevent a roll over. It mainly uses the abs so that it keeps all 4 wheels moving at the same speed. In a sense its acting like a locker in the rear and front differentials. As soon as one tire leaves the ground and senses that one (or more) wheel(s) is (are) moving at a different speed it will apply the brakes as needed to keep it moving the same speed as the other tires.
To better clarify, if the passenger front tire was to come off the ground, the brake would be applied to stop it from spinning and transfer power to the drivers side front. Same goes for the rear.
The advtrac does seem to work quite well from what I've seen on Wills05XLT4x4's truck when we have gone offroading together.
i think he was surprised when he found out he only had an open diff too given how well his truck preformed at the GWNF run
Is the lsd really that hard to find on 02-05's? I'm still fairly new to Explorers lol
Guess I'm one of the lucky ones.
