HiImBrian
- September 4, 2009
- St. Petersburg, Florida
- 2003 Explorer Eddie Bauer
This will only work with the v8 only and before the driveby wire was introduced. This one that i ordered is from stack racing, it was cheaper than the port and polished one.
The thing i like about both of these is there are both plug-n-play direct bolt ons.
The plenum i ordered was for the 4.6l mustang which does not have 2 pcv valves, so it was missing a hole for the brake vacumm booster. They sell one by trick flow with the correct opening. I simply removed one pcv valve and inserted an air breather, and routed brake booster. Both mods took less than an hour.
With the throttle body you will have to adjust your throttle cable with some zip ties down by the pedals.
Both pieces are 70mm which is 2mm more than stock.
I've got a V8 but I'm pretty sure my 03 is drive by wire.... Damn.
