Argentimage
MI
2005 Limited
So those “China tail lights “ are the ones that sent the electrucsl system crazy
Argentimage
MI
2005 Limited
No issues with forward illumination
domct203
Pilots The Beast
CT
2002 Explorer XLS
I had/have no problems with the trucks electrical system, perhaps you confused my post with the OP?
I had a bad LED bulb, problem followed the bulb.
Put in a new pair and all is well.
Mikerider
Renton, WA
2003 4x4 NBX 4.6
Got started on some upgrades to my 2003 NBX. First on the list was air. Built a bracket to slip in an ARB twin compressor.
Argentimage
MI
2005 Limited
No f150 too wide
Not sure they can be obtained now
I’d have to check close to $375 as I recall
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
No f150 too wide
So you have no idea the vehicle your grill was originally made for? Was it a custom fit only for our explorers. I’m comfortable trimming sanding and making it work but I’d find comfort in having an idea. The 04-08 F-150 grill is close as my buddy has one though yes they are larger. No offense but yours isn’t exactly flush and I have a feeling it was originally made for a pickup as I notice the grill protrudes past your headlight alittle bit and one could argue the one you have now is “too wide” but you made it work and it looks damn good.
Argentimage
MI
2005 Limited
Was for Asian Car
Been three years
Want one I’ll ask if they can ship because they (Asian retailers) got shut down
Yes little wide
Did not want to chop up everything
The GOR has to get cut up to make clearance
JD Arnold
Sparta, WI
2003 explorer no badges
Looked on here a bunch of times to see the biggest size tire I could fit on a bone stock 03. Turns out 235/85r16s just fit. No rubbing at full lock or at full tuck. Standard measurement is 31.7x9.4
doug625
Location
Michigan
Michigan
2002 XLS, 2007 XLT
Probably the last pictures of her I'll take, Trans is finally acting up at 199,000 miles but it's been a great vehicle and still looks pretty good. Btw 265/75 16 Cooper at3's no rubbing with no lift.
RustyBlue05
05 Ford Explorer Xlt
2005 xlt 4.0. Rancho Quicklift struts, procomp 7031 0mm offset 16x8's, 245/75r16 Goodyear Wrangler Duratracs with matching roof top spare, Hunter brush guard, uniden pro 520xl radio and 102" CB whip, amazon special led pods and light bar, roof basket from another explorer (think it was a factory accessory because it had an air deflector that said explorer on it when I bought it.)
El Monte
2004 Explorer XLT 4x4
Stock... Very stock. Took it through angeles crest highway to Palmdale. Planning to do a spacer lift and 265/75/16s A/T. Running smaller 225/70/16 temporarily cuz the old factory size ones are done.
BAMxi
2002 Explorer XLT
Figured it was time to share some shots of my '03 EB from 2018 so far. Many more adventures (and mods) planned!
Not sure if you're still active on here, but worst case maybe I can keep the photos thread alive for another day. These are great shots--your setup looks awesome. I checked out your website/instagram pages to creep on your lift/wheels/tires setup as I'm considering something similar for my explorer. I'm up in Columbia, MO but I frequent a lot of the NW Arkansas/Buffalo River spots I've seen you post about. How's your rig holding up to the overland life? Last time I was driving between Jasper and Ponca, I remember picturing my ex having some crazy timing chain catastrophe and trying to figure out what the hell I'd do on that road if the ol girl just grenaded herself. I think explorers like ours are a pretty good setup for exploring the ozarks. The terrain isn't crazy enough where you need a full on rock crawler to get most places but 4wd and some ground clearance will get you into some cool spots. Would love to pick your brain about some of the good wheeling trails you've hit up around Spfd and NW Arkansas areas.
4rd Xplora
On a Round Rock in Texas
2005 Eddie Bauer 2WD.
94Eddie
2010 Mountaineer Premier
Those 20" rims look good on a 3rd gen with the wheel well trim.
