3rd row power seating
Mark07 Mountaineer
2007 Mercury mountaineer
2007 mountaineer with power third row seating stuck in down position. I have done a limited amount of Internet research and appears to be latch assemblies and quite expensive. I am new to this forum and was wondering if there is a dyi thread or photos anywhere. I haven't found one yet on here but it appears this is a common problem and figured it has previously been addressed. Thanks
xyzabc33
06 EB V8
I had to do this just this past summer. When you press the button, the motor turns on, but the seat doesnt move correct? Im guessing its the drivers side seat, as they are the most common. I ended up removing the whole 3rd row seat assembly to fix. Wasnt hard to remove at all. There is a gear where the shaft and motor meet that strips out and doesnt let the seat move. I removed the motor and welded a socket to the end of the shaft and use a ratch to raise the seat when I need it. Total time for not knowing what I was doing, was about 4 hrs with basic handtools. Borrowed a grinder and had next door neighbor do the welding. Think I used a 11mm 3/8 drive. Sorry, doing this from memory.
xyzabc33
06 EB V8
I couldnt find pictures or video anywhere, when I did it. I got the idea to weld socket from somewhere on here, I think.
Bill MacLeod
Hamilton, Ontario
06 Ltd V-8
Try searching "3rd row rear seat motor".
I also had to replace the drivers side 3rd row seat motor. There was a large thread several years ago with lots of details and pics.
E Replaced my 3rd row power seat with a manual one. Stock 2006 -2010 Explorers 5
I 3rd row seats have no power Stock 2006 -2010 Explorers 1
D 2006 Explorer power 3rd row seat stuck Stock 2006 -2010 Explorers 4
L Remove power 3rd row seating Stock 2006 -2010 Explorers 0
R 3rd row latch assembly Stock 2006 -2010 Explorers 5
E 3rd Row Seating Stock 2006 -2010 Explorers 9
E Removing powered 3rd row seats Stock 2006 -2010 Explorers 7
T 3rd Row Seat. Stock 2006 -2010 Explorers 2
1 Replacing 3rd row seat belts Stock 2006 -2010 Explorers 0
M 3rd Row Seats from a 2002-2005 in a 2006 Stock 2006 -2010 Explorers 4
J Manual 3rd row seats? Stock 2006 -2010 Explorers 36
J 3rd row seat repair Stock 2006 -2010 Explorers 2
B Powered 3rd row seats, revisited? Stock 2006 -2010 Explorers 3
J 3rd row seat won't go up Stock 2006 -2010 Explorers 0
N 3rd row seat motor - any aftermarket part? Stock 2006 -2010 Explorers 5
Number4 Electronic 3rd row seats? Stock 2006 -2010 Explorers 7
J Adding a 3rd row seat - walkthrough Stock 2006 -2010 Explorers 24
R Add 3rd row seats on Ford Explorer 2007 Stock 2006 -2010 Explorers 1
C 3rd row seat motor Stock 2006 -2010 Explorers 3
L 06 Explorer factory 3rd row install? Stock 2006 -2010 Explorers 3
G Removing 3rd Row Headrests Stock 2006 -2010 Explorers 2
D 3rd row seat motor Stock 2006 -2010 Explorers 2
R 3rd row seat. Stock 2006 -2010 Explorers 1
M 2006 Mercury Mountaineer 3rd Row HELP Stock 2006 -2010 Explorers 1
B 3rd row seats Stock 2006 -2010 Explorers 1
2 3rd row passenger seat stopped working Stock 2006 -2010 Explorers 0
J 3rd row seat broke? Stock 2006 -2010 Explorers 1
G 3rd row electric seat back won't elevate. Stock 2006 -2010 Explorers 130
D 3rd row seat ???? Stock 2006 -2010 Explorers 15
D 3rd Row Speakers Stock 2006 -2010 Explorers 1
D 2006 Ford Explorer 3rd Row Seating Stock 2006 -2010 Explorers 0
K Wanted 2008 biege 3rd row seat. Stock 2006 -2010 Explorers 0
G Can I add 3rd row seats? Stock 2006 -2010 Explorers 1
B 3rd Row Seat Question Stock 2006 -2010 Explorers 15
94Eddie Are 3rd & 4th gen Mountaineer headlight assemblies interchangeable? Stock 2006 -2010 Explorers 1
0 5R55S shift shudder between 3rd and 4th gear Stock 2006 -2010 Explorers 0
N 3rd Gen Guy needs some help Stock 2006 -2010 Explorers 6
G 2006 Explorer XLT with 71K Miles 3rd Shift Problem Stock 2006 -2010 Explorers 4
1 3rd Brake light lense, whats missing? Stock 2006 -2010 Explorers 3
L Are the 4th generation (2006 - 2010) more reliable than the 3rd gen? ('02 - '05) Stock 2006 -2010 Explorers 4
P Are the 4th Generation Explorers any better than 3rd ? Stock 2006 -2010 Explorers 1
Stic-o are 3rd and 4th gen rear bumpers the same? Stock 2006 -2010 Explorers 2
M Need Advice: 3rd vs 4th Gen Ex Stock 2006 -2010 Explorers 2
B 3rd gen vs 4th gen Stock 2006 -2010 Explorers 5
V starting out in 3rd gear Stock 2006 -2010 Explorers 2
S 2nd to 3rd "jerk" Stock 2006 -2010 Explorers 23
E Convert power 3rd seat to amnual. Stock 2006 -2010 Explorers 0
C 3rd brake light Stock 2006 -2010 Explorers 0
1 Second Row Chairs Console Fold Flat? Stock 2006 -2010 Explorers 1
K 2nd row seat swap Stock 2006 -2010 Explorers 1
Similar threads
