wilpetty
- January 29, 2020
- austin tx
- 2004 explorer xlt
I have a 2003 4.0L explorer. I had timing job and new valves put in the car by mechanic. He timed bank 1 180* out, and I retimed the vehicle. I still have a misfire on cylinder 2, and O2 sensor has a stuck on lean code. New plugs, New Wires, New Coil,...Maybe he did not install new valves? What else could this be? Checked the plug, and it looked fine. May buy compression tester to help diagnose if the valve is bent. There is a loud tapping sound on that side..I thought it was an exhaust leak at first, but noise is coming from within valve cover.
