My build starts in two weeks and there a few questions I need to find answers to and a few details to nail down.
1) With SI Valves (0.020 oversize), (988-12) comp cam springs, and comp cam retainers (1730-12), What locks do I need? Part numbers please.
2) Would it be beneficial to run the older style Alabama head (90TM) with flat top pistons (3155HC-5MM on summit) vs oem spec dished piston with Alabama 98TM heads? Important tidbit, the block will be decked to whatever it can be cut down to, still researching that one. Trying to get to around 10:1/10.5:1 compression
3) Using the older style heads, what is the limit on porting and polishing the intake and exhaust runners? With the newer style heads, what should the final finish be on the intake runner? I had heard/read smooth, but not polished. Anyone care to confirm or deny?
4) Running the above setup with the 422 cam, do ARP rod bolts and main studs warrant the cost? This setup will never be FI or sprayed.
5) What is the preferred 24lb injector? Part #? Do the 24lbs from a mustang work?
