How to: - 4.0 OHV Refresh | Page 13 | Ford Explorer - Ford Ranger Forums - Serious Explorations
How to: 4.0 OHV Refresh
donalds
Location
Stem
Nc
1999 ford explorer sohc
donalds
Location
Stem
Nc
Get all new ones
Because that some of the porcelain is different on other plugs too it's sticking out more than others it seems like the core of the plugs are being pushed out might have some faulty plugs here
Compare those plugs really well to your new ones the color looks good though
97Sandbox
Milwaukee, WI
2000 Explorer Sport
Get all new ones
Any recommendations that are better than these Motocraft plugs? I usually trust FoMoCo for stuff like this, but it seems their plugs may not be up to snuff.
Fix4Dirt
Get a Load O' This Guy!
Los Angeles, CA
1998 XLT 4x4
have had good luck with ngk
donalds
Location
Stem
Nc
From doing lots of reading on this forum I can tell you motorcraft plugs only this is just a weird situation with your plugs People find when they run other plugs they get misfires at idle stuff like that
If I had to pick an after market I would say autolite
97Sandbox
Milwaukee, WI
2000 Explorer Sport
After taking another look at the plugs in-person, the porcelain protrusion looks pretty consistent across all six plugs -- I think it's just something goofy with the angle of the picture that made them look different.
And for those eagerly awaiting, leakdown results are in!
Cyl#1: 64%, audible hissing from oil filler neck and dip stick tube, no bubbles from radiator
Cyl#4: 90%, audible hissing from oil filler neck, no bubbles from radiator
Cyl#2: 76%, audible hissing from oil filler neck and intake (with throttle open), no bubbles from radiator
Cyl#5: 83%, audible hissing from oil filler neck and dip stick tube, no bubbles from radiator
Cyl#3: 94%, audible hissing from oil filler neck and dip stick tube, no bubbles from radiator
Cyl#6: 55%, audible hissing from oil filler neck, dip stick tube, and intake, no bubbles from radiator
I was surprised not to see any radiator bubbles -- could that be because I didn't remove the thermostat?
Regardless, I've got unhealthy cylinders in both banks.
EDIT: I should add, the percentages above are the static pressure, not the percent leakage.
97Sandbox
Milwaukee, WI
2000 Explorer Sport
After doing some reading, I'm thinking the biggest piece of information the leakdown test told me is that this engine likely has some really worn rings (not entirely surprising for an engine with 260k that may or may not have always been well taken care of). Another observation consistent with ring wear was a gasoline smell as the air blew out of the oil filler neck -- I'm assuming there's quite a bit of blow-by in at least a couple of cylinders.
Overall, I'm still thinking the dirty coolant bubbles are the result of a minimally blown head gasket or slightly cracked head that only allows combustion gas into the cooling system when the engine is running hot and everything expands. While reman heads and new gaskets may solve the combustion in the cooling system issue and even the leaky intake valve, they won't do anything to stop blow-by. That being the case, I'm not sure it's worth it to put a new top end on a worn out rotating assembly and/or block.
Any thoughts from you Explorer experts before I dump a bottle of head gasket repair in and run the old 4.0 till it blows?
Clutch5sp
TX
2000 Explorer XLT
Hi...if there is a crack in the head(s), there very well could be air passing thru to be heard sorta like a valve seat being bad. This tricked me while doing the tests. With 260k on the counter, there could be all sorts of probs not just one.....rings, valves, cracks, leaking gaskets. Decide if you will want to save this engine core before something serious goes bad like spun bearings, rods thru block etc...
97Sandbox
Milwaukee, WI
2000 Explorer Sport
Unfortunately, I just don't have the space to rebuild this engine where I live currently. I hope to move somewhere with a bigger garage or even a shop by the summer, so I'd realistically just like to limp this engine along until then (hence the reason I'd actually consider a temporary fix kind of product).
When I do eventually pull the 4.0 out, I'd really rather replace it with something that has a couple more cylinders, so the 4.0 core doesn't mean all that much to me. I wanted to get to know the OHV and give my engine a second lease on life when I bought my Sport, but it doesn't seem like this one is worth saving.
If anyone knows someone in the Midwest who's dumping a healthy OHV for cheap in order to swap in a V8, I'd still be willing to try a like-for-like swap to buy me time until my own V8 sawp. I just can't justify $3k for a reman long block that doesn't get me any closer to my end goals.
Clutch5sp
TX
2000 Explorer XLT
Now I understand. You did mention an upgrade in cylinder qty in the beginning of your thread.
97Sandbox
Milwaukee, WI
2000 Explorer Sport
No problem! Your prior reply actually did prompt me do some more thinking. It looks like I could buy a supposedly healthy 100-150k mile OHV for about $550. Some of the refresh components from my current engine could be swapped over (timing set, ignition system, cooling system), but a lot would still need to be re-purchased and reinstalled on the "new" engine (gaskets and hardware mostly). By my estimates, I could swap in and lightly refresh a good used engine for about $1000 including needing to purchase an engine hoist. To do the same to a engine with bad heads (factoring for more gaskets and reman heads) would be more like $1500, so there's no money saved going that route. Either way, these options are both well below the roughly $3500 it'd cost to get a reman 4.0 and install it, unless of course the used engine turns out to have bad rings like my current one.
This leaves me with a couple questions:
  • Is it even reasonable to think I could pick up a well-maintained 100-150k OHV that won't leave me in a similar situation down the road?
  • Short of running a compression test, lookdown test, or driving the truck I pull an engine from (all of which I expect I won't be able to do prior to purchase), what are some tips for evaluating the health of a used OHV?
If $1000 and a weekend of hard work gets me one of those "bulletproof" OHVs that folks on here rave about, I'm interested. But if it's more likely I'll just be throwing time and money at another clunker, I'd rather save up for a V8.
Clutch5sp
TX
2000 Explorer XLT
Just an FYI.... searched a car-parts thingie in & around Dallas and there is a crap-ton of 5.0L 99-01 explorers sitting in salvage yards. There is some legal ordeal they can't sell the entire truck butt you can get all the parts ya want off em.
There seems to be a lot involved in swapping V6 to V8. Not as simple as engine trans ecu cluster. There is PATS fuel lines exhaust cooling etc...you probably know. Wouldn't it be easier to start with one that had the V8 originally and go from there? Saw one on CL for $1,500 with probs butt it ran (they said).
Once a Saturday morning TV show POWER NATION redid a Ranger to have a 4.6 L. Of course they have unlimited budget & tools galore, it was still neato to see it all come together.
Truthfully, I'd rather have an Expedition. Never liked the Explorer driving long distance. Wife loves it....not too big or small.
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
interesting! never knew that always ysed aftermarker like ngk bosch etc snd bever had any misses, good to keep in mind! thiught it was a v8 only thing interesting
97Sandbox
Milwaukee, WI
2000 Explorer Sport
I noticed the same thing here in SE Wisconsin.
There is a lot involved (I'll start a new thread shortly to begin discussing that), but since Ford never made a 5.0, manual trans, two-door Explorer you have to build them yourself!
