4.0 OHV SWAP, Old Engine Intake has 2 fuel lines, new engine intake has only one? | Ford Explorer Forums - Serious Explorations
FLSnake
Bradenton, FL
97 XLT
I doing an engine swap on a 1998 Explorer 4.0 OHV V6.
The engine I got from the salvage yard ( maybe from a 1999) has only one fuel line going to the lower intake on the right front.
The engine I removed has 2 fuel lines going to the lower intake, one on the right front and another on the left rear.
Is there a work around or should I swap the lower intakes?
Thanks
Use your old fuel rail and manifold. Ford switched to an returnless fuel system. Otherwise, you need the wiring harness and ECU from the newer truck.
Can I just swap the fuel rail instead of the whole lower intake manifold?
the upper and lower didn't change?
